My Acura radio code doesn't work?
Re: My Acura radio code doesn't work?
try this, found it online
If you have a 2007 Acura TSX, and know the radio code, turn on the key, without the car running, press and hold the radio power button for about 10 seconds, until the display above the radio shows code, then turn the right **** of the radio, it will change the number on the display from 1 - 9, you will turn the **** to the first number you want, then push the right button in just once, then turn the **** to the second number, push the **** in, then turn to the third number - push the right **** button in, do this for all five radio code numbers, after the last number is put in, the radio will work again. If you cannot find the radio code in the owners manual, you will find it on the side of the glove box after you open it, it's on a sticker stuck to the outside of the glove box.
