Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Found 02 TLS for $1050
Old 07-18-2018, 12:08 AM
Kirt Thelander's Avatar
Default Found 02 TLS for $1050
Found 02 TLS with almost 300k.
Lady lives in a nicer area of my state, (Arlington wa) so I assume basic maintenance has been at least half *** taken care of.
Also I have owned an f22b and b18a so I am pretty comfortable working on those motors.
Two main questions
Is 300k a lot for an early j series lets say if it hadnt had any good maintenance done?
And
Mechanically, I understand a motor is a motor, but do j series operate any different than f/h/b/d motors?
Are they still pgm- fi or whatever Honda calls it? So basically the idle is still set by the screw on the TB and uses a MAP and not a MASS and the intake is still has a negative vaccum? Egr? Etc. And everything pretty much operates the same but just 2 more cylinders? This sounds ignorant huh? I'm not sure how else to explain it.
One minor question. How hard is it to check the timing belt? With I4s I have gotten in the habit of taking a rachet a 12 mm with me when I inspect a car before I buy it cuz all it takes is 5 bolts to pop off the valve cover and look at the timing belt. Probably not so easy on a j series?
​​​​​​And one more, when did Honda change from pgm fi to something more modern and efficient?
I really might want this car.
Sorry
Thank you
Kirt
2.0SLEEVED
15
12-10-2012 06:31 PM
Projekt_2nr
03-10-2007 02:00 PM
justalilbuzzbomb99
15
10-23-2006 09:10 AM
99eciVic
16
07-08-2004 05:38 AM
Quick Reply: Found 02 TLS for $1050
