crankshaft position sensor problem help!!!
I have 96 acura TL, I just change out the spark plugs then 2 days later then
engine is stalling and can't rev over 3000 rpm the engine light is on, so i took it to autozone to pull up the code. then it pull up 6 codes one of them is po335 (crankshaft position sensor) so do i have to change out the sensor? but its $350 for the sensor!! |
Re: crankshaft position sensor problem help!!! (Tonyng101)
Yes replace it, but I would try and get one from a salvage yard. You might also want to look into see what other models share the same sensor. Might find more hondas in the yard than acuras.
Re: crankshaft position sensor problem help!!! (Honda Tool)
do you know where the sensor is or how to replace it ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Tool »</TD></TR><TR><TD CLASS="quote"> You might also want to look into see what other models share the same sensor. Might find more hondas in the yard than acuras.</TD></TR></TABLE>
I'm sure it's a "Honda" parts. $350 is way too high for a sensor. Maybe the "Honda" version is only $100? Check shops like Autozone too to look things up. |
