B20/VTEC turbo AWD CR-V...has anyone done it?
Has anyone done a turbo, AWD CRV? Whether it be B20/VTEC or straight B20?
Re: B20/VTEC turbo AWD CR-V...has anyone done it? (boostincoupe)
Yes, its been done before. B20 Vtec and turbo.. I saw it on a Super street mag couple years ago.. Also driven by a girl as well if memory serves me right.. https://honda-tech.com/forums/images...es/emsmile.gif
Would the original B20 engine be a better candidate for a turbo due to its lower compression? Could the same be achieved with the later with thicker head gasket?
Just toying with the idea... |
Re: B20/VTEC turbo AWD CR-V...has anyone done it? (b18bvtec4drteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bvtec4drteg »</TD></TR><TR><TD CLASS="quote">Yes, its been done before. B20 Vtec and turbo.. I saw it on a Super street mag couple years ago.. Also driven by a girl as well if memory serves me right.. https://honda-tech.com/forums/images...es/emsmile.gif </TD></TR></TABLE>
I think that was a FWD model...my dad had a 98 crv awd....i was thinking of doing something like that but i'd have to do a manual tranny swap and itll cost way too much for everything... |
Re: B20/VTEC turbo AWD CR-V...has anyone done it? (JDMITR22)
yes it can be done, however stock b20 sleeves are thin, and if you get a boost spike its possible to crack a sleeve, and depending on what VTEC head you use, i think you will actually drop compression due to the head cc
no she dropped in a gsr and used a greddy kit |
Re: B20/VTEC turbo AWD CR-V...has anyone done it? (RuthlessEF-9)
I have a 97' CRV and am gettin ready to install my turbo kit one of these next couple days. I have a friend who has a b20/VTEC hatch and it flies, I could only imagine the 2 of them together. But if the install was done wrong then its a timebomb.
heres my site if you wanna check it out; http://www.cardomain.com/membe...age=1 |
I've had a B20/VTEC in my civic for about 3 yrs. now it still runs great. but if you are giong to put a VTEC head you might want to think about swaping out the main bearings to GSR's so i can handle the higher RPMs.(don't want to spin a bearing) I am now currently building another block for my CR-V which will be sleeved for turbo and will also have a VTEC head bolted on to it. By spring my AWD CR-V will be pushing @400 HP. good times https://honda-tech.com/forums/images...es/emsmile.gif
Re: B20/VTEC turbo AWD CR-V...has anyone done it? (the real allmotormike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the real allmotormike »</TD></TR><TR><TD CLASS="quote">I've had a B20/VTEC in my civic for about 3 yrs. now it still runs great. but if you are giong to put a VTEC head you might want to think about swaping out the main bearings to GSR's so i can handle the higher RPMs.(don't want to spin a bearing) I am now currently building another block for my CR-V which will be sleeved for turbo and will also have a VTEC head bolted on to it. By spring my AWD CR-V will be pushing @400 HP. good times https://honda-tech.com/forums/images...es/emsmile.gif </TD></TR></TABLE>
Do you think the Realtime 4WD will be able to handle that much power? Keep us updated. https://honda-tech.com/forums/images/smilies/emthup.gif |
do anyone know if the AWD system will work on a hatchback?
Re: B20/VTEC turbo AWD CR-V...has anyone done it? (SIR-nesta)
I think it was Honda Tuning magainze, (or maybe another Honda magazine). That put the CRV's Real Time 4-WD system in a integra. They had a big write up on it in that issue of the magazine, maybe search for the topic and check that article out to see if it'll fit. That'd be sick as shit if it did 2.
i was just thinking about this yesterday.Saw a crv on the road and was thinking has anyone put a type r in an awd crv that thing would probably jump of the line depite the weight
Re: B20/VTEC turbo AWD CR-V...has anyone done it? (Sushiboy)
I hope so if not I'm going to take out the real time slip disc set-up and weld everthing up to make it all-time 4wd. but i'll keep you all updated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuthlessEF-9 »</TD></TR><TR><TD CLASS="quote">
no she dropped in a gsr and used a greddy kit</TD></TR></TABLE> no she dropped a gsr head on a cr-v block...http://www.superstreetonline.c...3784/that was a bad ass cr-v https://honda-tech.com/forums/images/smilies/emthup.gif . trippy when i saw it for the first time. didn't beilieve i would ever see a turbocharged cr-v. https://honda-tech.com/forums/images/smilies/emthup.gif to autolink and their crew... |
Re: B20/VTEC turbo AWD CR-V...has anyone done it? (pdotjones)
sweet crv....glad to see someone did it...... https://honda-tech.com/forums/images/smilies/emthup.gif
Re: B20/VTEC turbo AWD CR-V...has anyone done it? (hybridej7)
I have the Honda Tuning Mad with me at home and all they did was take out all of the unnecessary pumps and clutches and welded it all together.
Re: (jdmgsr_eg6)
save your self the money and just buy the head and replace the main bearings. If you were to put a type r engine in you V you would lose off the line everytime. because you would loose your lowend torque, not a good idea. I was using a b16 in my integra as a spare engine and i could really feel the loss of low end power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sushiboy »</TD></TR><TR><TD CLASS="quote">Do you think the Realtime 4WD will be able to handle that much power? Keep us updated. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
According to the guy who welded diff so that his Integra (with CRV AWD) could be RWD, the axels can handle a whole lot of power. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: B20/VTEC turbo AWD CR-V...has anyone done it? (mixmastabob)
the rear axles on a crv are like the thickness of my finger, i dont see that holding much power at all.
Re: B20/VTEC turbo AWD CR-V...has anyone done it? (BonerBen)
My buddy owns/built the Integra. So fun to ride in. Busting donuts in an Integra, awesome.
http://www.brailleauto.com/index-1.html |
just throw a JRSC on whatever you got (FWD or AWD) and call it a day.
