anyone pulled a engine outa a 01 TL? please help...
hey guys im pulling the motor outa my girls 01 TL cuz the eninge blew. but if anyone has done this before ... where did you dissconnect the wirring harness? do you have to pull the dash to get to the plugs? or do you have to pull the intake mani off to get the injector plugs to pull the harness off the eninge? PLEASE HELP thanks
Re: anyone pulled a engine outa a 01 TL? please help... (B18aHatch)
you disconnect everything at the engine and lable it. I believe that all you need to do is remove plastic engine cover to get to the wire harness for injectors
Re: anyone pulled a engine outa a 01 TL? please help... (YeuEmMaiMai)
no the harnes for the injectors are under the intake mani. i have the whole harness unpluged from the engine but then got to the injectors and it is under the mani... soooo seeing if ne one has ever done this before...
if you want more answer try going to acurazine.com and look for kris i forget his sn but its like fftsmy or something like that he has like 35,000 post and he can help you with any questions you have.
Re: (tnluder)
the way i do them is remove the harness their is a main harness and unplug from the pcm. is their ia easier way to to this ? not from what i have seen and done.
cristegra09
15
05-11-2009 08:38 PM
