93 Legend Rotor/stud problems **HELP**
Got the rotor off .. an theres a little disc where the studs mount in.. i need to put new studs in.. how do i change them.. pleasee help me lol.. pictures anything.. thank you
I am pretty sure that you need to take the whole knuckle assembly to a machine shop and have them press out the old studs and replace them. That is if you cant remove them on the car because of clearences behind the stud. If there is enuf room to take them out, then just beat the **** outa them with a hammer and they will eventually come out. If you take it to a machine shop then they will prolly have to install a new wheel bearing too.
Good luck
Good luck
coupedup
06-26-2003 06:12 AM
