92 legend brake rotors?
does anyone make slot/drill Legend GS rotors? (the front ones).
if so.. are they they same spec?
i looked it up at powerslot... and it gave the specs on the front legend rotors... then...i looked at the specs on a 99 prelude front rotors... it gives the same specs.. BUT... when i compared the two rotors side by side.. they're different.
any thoughts?
any thoughts?
Re: 92 legend brake rotors? (Honda318dx)
well.. i'm trying to install the NSX calipers on the front of my 99 prelude.. and i've heard that it requires legend GS front rotors.
now.. if i use OEM prelude rotors... how well would that work?
i think the Legend rotors are thicker and larger in diameter? i may be wrong. would i need to use some sort of shim to compensate?
any help is appreciated.
