Rounded the VTEC solenoid bolt. Help
Tried removing my VTEC solenoid today, to change the screen/gasket, plus give it a good cleaning. I figure it's due after 133k miles...
The first bolt I tried removing would not budge. Not only would it not budge, but due to the bad angle and lack of visibility, I managed to make it a bit round. My 10mm socket would no longer grip it. So, went at it with a Craftsman bolt-out, which is supposed to grip the head and help you remove it. Nope. Turns out, the bolt is rusted into place to the point that the bolt-out tool just made the head even rounder. So now, the VTEC solenoid is being held in place by a bolt that has a round head, smaller than a 10mm, larger than a 9mm, the #4 bolt-out won't grip it, and the #2 won't fit on the head. Not only that, I haven't even attempted to remove the other 2 bolts that hold it in place. Help. |
Re: Well, that was dumb...
If it ain't broke....
Originally Posted by prelude_h22vtec
(Post 47966485)
Hit it with some good penetrating oil (not WD-40) and let it soak overnight. Then use either a) crow's foot b) a wobble extension c) a socket joint.
If the bolt head is rounded you can try to hammer a socket on it. |
(Post 47966485)
Hammering a smaller socket on works a lot of times. If that doesn't work I pull out the cut off wheel.
Originally Posted by lazlong
(Post 47966512)
Originally Posted by Sugar Shane
(Post 47966679)
there isn't a lot of room between the engine and the firewall to swing a hammer.
and ALWAYS use a 6 point with bolts that are hard to get out, also... how is it rusted to Aluminuim?
hope its gone your way , dam that sucks :(
leave it alone
I've had luck with some vise grips
Originally Posted by Fliptard
(Post 47970093)
As for how it's rusted into place, the bolts go through the VTEC solenoid's heat shield before entering the head, and the heat shield is made of a metal that does get quite rusty after 10+ years on the car. I imagine that once I'm able to break them loose, they'll (hopefully) come out without a fight. I did have the good sense to buy new ones before I attempted to remove them, once I saw how rusted they were. |
Try using some PB Blaster. What I had used to get a rounded off nut taken off was i think a brinks socket set and it worked perfectly to get it off. not too sure if that is the same as the craftsmen.
my advice is with it's location leave it alone. You'll probably only make it worse from here.
Originally Posted by Type-Spaz
(Post 47978795)
Plus, (and I know I'm not alone here) just knowing that there's a damaged fastener holding something onto my car's engine is enough to keep me up at night. I'm giving it one more shot, but if I can't remove it myself, I'm not too proud to admit defeat and seek help from professionals. |
Re: Rounded the VTEC solenoid bolt. Help
this will work forsure..... if you really want that bolt out.
http://www.google.com/imgres?q=turbo...9,r:1,s:0,i:80 THEY HAVE NEVER FAILED FOR ME |
Originally Posted by 10psiLsEf2
(Post 47985264)
with an impact?
Pull the engine then if it's that bad... it's a tough spot to get into. You can have it out and back in in a day
(Post 47985384)
(Post 47985384)
Op post pics please... I also asked if you used the extracters with a impact or hAND ratchet. |
(Post 47999206)
