Password:JDM Carbon Kevlar PowerChamber Intake (DC5 / EP3)
What do you guys think? Discuss
http://passwordjdm.com/Passwor....aspx
I personally think this is the next best thing for us DC5 EP3 owners. I like the filter being in the front so there's air going directly to the filter, unlike the V2 with the filter sitting in the back. The numbers is put up look pretty good aswell.
Re: Password:JDM Carbon Kevlar PowerChamber Intake (JDMk20R)
it doesn't seem to perform to badly as far as the graphs show on the site, however personally i don't like the look of it, sure its carbon fiber, but from what i understood the whale ***** before it got heat soaked quickly and gains became negligible. Only way to find out how good it is, is for someone to buy it.....i wouldn't put it on my car though...my 2 cents. Im sure many would disagree. for innovation though.
Honda-Tech Order of Merit
Re: Password:JDM Carbon Kevlar PowerChamber Intake (Godspeed07)
im tempted to sell my new injen cai and try this... it says you need to relocate your battery but they also sell a relocation kit for this.
* B A N N E D *
Re: (VBPType-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VBPType-S »</TD></TR><TR><TD CLASS="quote">that thing is a crock of ****. I want to see some dyno #'s without letting the car completely cool down between runs.
18 whp my ***</TD></TR></TABLE> ya i wanna see dyno's of it with the hood closed too for real world conditions. But it stills looks sexy
Re: (k20z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20z »</TD></TR><TR><TD CLASS="quote"> ya i wanna see dyno's of it with the hood closed too for real world conditions. But it stills looks sexy </TD></TR></TABLE>
X2
X2
Re: (Rev4Ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rev4Ever »</TD></TR><TR><TD CLASS="quote">Nice marketing for PasswordJDM to force people on buying the battery relocator from them at the same time. </TD></TR></TABLE>
Which is dumb because I was going to grab this up. Seeing how it would match my spoon coil cover perfectly, but i'm not going to go to that small battery. Not that great for a daily driver.
The package deal they have goin is 469 with the battery and relocator kit and for those that wanna see pics of where the battery goes here's an installed pic.
Re: (VBPType-S)
The filter is always going to be seeing hot air from behind the radiator - that can't be great. Also, air loses velocity every 7 degrees of travel - that has a 180 degree turn right off the bat, then the air has another 90 degree change in direction once it enters the intake plenum and turns to enter a runner. I'm not knocking the design, nor am I endorsing it, I'd expect a torque sacrifice for a few top end HP. Personally, I'm more about how much is under the curve, not just peak numbers. I'll be anxious to see a real world dyno. sheet.
Re: (Mr.Kantot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Kantot »</TD></TR><TR><TD CLASS="quote">they ldidnt let heatsoak come into play. they cooled down the car after each run. so ill just wait for someone to buy it and dyno it.</TD></TR></TABLE>
heatsoak is my new favorite word! it sounds so technical! and so prevalent in this forum!
I'm not an expert in thermodynamics but I can tell you from experience, from working with a customer that custom made his own carbon fiber turbo ducts and plenums - carbon fiber 'heatsoak' will not be an issue. lol.
* B A N N E D *
Re: (ReallySlowEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReallySlowEg »</TD></TR><TR><TD CLASS="quote">
Which is dumb because I was going to grab this up. Seeing how it would match my spoon coil cover perfectly, but i'm not going to go to that small battery. Not that great for a daily driver.</TD></TR></TABLE> the smaller battery is better i believes. Quoted from CRSX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickyute;14115495 »</TD></TR><TR><TD CLASS="quote">680 cranking amps for 5 seconds
595 cranking amps for 10 seconds
525 cranking amps for 20 seconds
Short circuit current over 1800A
17 amp hours
25 minute reserve capacity with 25amp load
Female brass terminal w/M6 SS bolt
With metal jacket
Length 7 1/4"
Width 3 1/8"
Height 6 5/8"
Weight 15.4 lb
stock is 410 CCA ...
on a FG2/FA5 ... i don't think it's different for u guys ...</TD></TR></TABLE>
17 amp hours
With metal jacket
Length 7 1/4"
Width 3 1/8"
Height 6 5/8"
Weight 15.4 lb
Re: (Thomas Jenkinson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thomas Jenkinson »</TD></TR><TR><TD CLASS="quote">The filter is always going to be seeing hot air from behind the radiator - that can't be great. Also, air loses velocity every 7 degrees of travel - that has a 180 degree turn right off the bat, then the air has another 90 degree change in direction once it enters the intake plenum and turns to enter a runner. I'm not knocking the design, nor am I endorsing it, I'd expect a torque sacrifice for a few top end HP. Personally, I'm more about how much is under the curve, not just peak numbers. I'll be anxious to see a real world dyno. sheet.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thomas Jenkinson »</TD></TR><TR><TD CLASS="quote">
I'm not an expert in thermodynamics but I can tell you from experience, from working with a customer that custom made his own carbon fiber turbo ducts and plenums - carbon fiber 'heatsoak' will not be an issue. lol.</TD></TR></TABLE>
Well put:
LOL!
Well put:
LOL!
