k20a, k20a1, k20a2, k20a3, k20z1, k20z3 whats the difference
#27
Re: k20a, k20a1, k20a2, k20a3, k20z1, k20z3 whats the difference
No problem , all the information is on line if you look .Funny how there was so much mis information in this post , i don't say they were wrong just uninformed . i live in Asia and half of the printed info on Honda s is wrong ( for what there is where i live) . Honda made country specific cars over here that don't exist in other places . like a carburetor equipped d15 EGs , and non vtec b18b1 in EK civics .
#28
I've heard that the base model RSX is better for boosting. Has anyone discovered this for themselves?
#31
K20Z2
Found in:
2006- Acura CSX (Canada)
Displacement: 1,998 cc (121.9 cu in)
Compression: 9.6:1
Power: 155 hp (114 kW) @ 6000 rpm (SAE net J1349 Rev 8/04)
Torque: 139 ft·lbf (188 N·m) @ 4500 rpm / 188 N·m @ 4200 rpm (Singapore)
Redline: 6800 rpm
2006- Honda Civic (JDM)
Compression: 9.6:1
Redline: 6800 rpm
2006- Honda Accord(Europe)
Displacement: 1998 cc
Compression: 9.6:1
Redline: 6800 rpm
Found in:
Compression: 9.6:1
Redline: 6800 rpm
Compression: 9.6:1
Redline: 6800 rpm
Compression: 9.6:1
Redline: 6800 rpm
#33
wait a minute... so a stock ep3 is already equiped with a k20?! specifcally k20a3?
#35
Sorry to try and bring this thread back to life. But i have 1 Major question. Can you turn the Base Model RSX motor into a Type S motor. it seems like the they are very similar with a slight variation. The cooling thing in the type S compared to a standard thing with the cams. stronger pistons and compression. i'm asking these questions because i recently found a Base model motor for 700. and i'm about to do a swap in my 94 LS. i've also owned a Base 06 rsx and it seemed pretty decent and everybody was saying it's better for boost because of the low Comp. please help!!!
#36
and yes, an ep3 has the same motor as the base rsx
#37
K20
[edit]K20A
The 2.0L (1998 cc) K20 engines have 86 mm (3.39 in) bore and 86 mm (3.39 in) stroke. The 2.2L (2157 cc) version has 87.0 mm (3.43 in) bore & 90.7 mm (3.57 in) stroke.
Found in:
Honda Civic Mugen RR Advanced Concept
Displacement: 2,157 cc (131.6 cu in)
Power: 260 PS (256 hp/191 kW) @ 8250 rpm
Torque: 237 N·m (175 lb·ft) @ 6750 rpm
Honda Civic Mugen RR (Honda ABA-FD2)
Compression: 11.7:1
Power: 225 PS (222 hp/165 kW) @ 8000 rpm
Torque: 218 N·m (161 lb·ft) @ 7000 rpm
Redline: 8400 rpm
2007- Honda Civic Type-R (FD2)
Compression: 11.7:1
Power: 222 bhp (225 PS, 165 kW) @ 8000 rpm
Torque: 158 ft·lbf (215 N·m) @ 7000 rpm
Redline: 8600 rpm
2001-2006 Honda Civic Type-R (EP3)
Compression: 11.5:1
Power: 212 bhp (218 PS, 158 kW) @ 8000 rpm
Torque: 149 ft·lbf (202 N·m) @ 7000 rpm
Redline: 8600 rpm
2001-2007 Honda Integra Type-R (DC5)
Compression: 11.5:1
Power: 220 bhp (220 PS, 162 kW) @ 8000 rpm
Torque: 152 ft·lbf (206 N·m) @ 7000 rpm
Redline: 8600 rpm
I-VTEC Engagement: 6200 rpm
2003-2007 Honda Accord Euro-R
Compression: 11.5:1
Power: 217 bhp (220 PS, 162 kW) @ 8000 rpm
Torque: 152 f·lbf (206 N·m) @ 7000 rpm
Redline: 8800 rpm
[edit]K20A2
Found in:
2002-2004 Acura RSX Type-S and 2002-2005 Honda Civic Type R (EP3, European)
Compression: 11.0:1
Power: 200 ps/201 hp (148 kW) @ 7400 rpm
Torque: 146 ft·lbf (193N·m) @ 5600 rpm
Redline: 7900 rpm
I-VTEC engagement: 5800 rpm
[edit]K20A3
Found In
2002-2005 Honda Civic Si
2002-2004 Acura RSX
Compression: 9.8:1
Power: 160(120 kW) @ 6500 rpm(SAE net J1349 Rev 8/04)
Torque: 142 lb·ft (193 N·m)* (191 N·m) @ 4000 rpm(SAE net J1349 Rev 8/04)
Redline: 6800 rpm
[edit]K20A4
Found in:
2003-2005 Honda Accord (UC1)
2006-2008 Honda Accord (UC3)
2001-2007 Honda CR-V (RD5)
2000-2003 Honda Stream (RN1)
2004-2007 Honda Stream (RN3)
[edit]K20A6
Found in:
2003-2005 Honda Accord (European)
[edit]K20Z1
Found in:
2005-2006 Acura RSX-S
Compression: 11.0:1
Power: 210 hp (154 kW) @ 7800 rpm (SAE net J1349 Rev 8/04)
Torque: 143 ft·lbf (194 N·m) @ 7000 rpm (SAE net J1349 Rev 8/04)
Redline: 8300 rpm
i-VTEC Engagement Window:5800 rpm
[edit]K20Z2
Found in:
Compression: 9.6:1
Redline: 6800 rpm
Compression: 9.6:1
Redline: 6800 rpm
Compression: 9.6:1
Redline: 6800 rpm
[edit]K20Z3
This inline-4 cylinder internal combustion engine is found in the US market Honda Civic Si (2006+) & Canadian market Acura CSX Type-S. It has an aluminum block with an aluminum head, and a bore and stroke of 86 mm x 86 mm, resulting in a 2.0 Liter displacement.
Found in:
2006-2009 Honda Civic Si (FG2 - Coupe & FA5 - Sedan), 2007 Acura CSX Type-S
Displacement : 1,998 cc (121.9 cu in)
Compression : 11.0:1
Power: 197 bhp (147 kW) @ 7800 rpm (sae NET Rev 8/04)
Torque: 139 ft·lbf (189 N·m) @ 6200 rpm (sae NET Rev 8/04)
Redline: 8000 rpm
i-VTEC Engagement Window:5600 rpm
[edit]K20Z4
This inline-4 cylinder internal combustion engine is found in the redesigned Honda Civic Type-R (FN2). It has an aluminium block with an aluminium head, and a bore and stroke of 86 mm*86 mm, resulting in a 1,998 cc (121.9 cu in) displacement.
Found in:
2007 Honda Civic Type-R (FN2) (Europe Market)
Power: 222 bhp (201 PS, 148 kW) @ 7600 rpm
Torque: 142 ft·lbf (193 N·m) @ 5600 rpm
Redline: 8200 rpm
i-VTEC Engagement: 5,400 rpm
[edit]K23
[edit]K23A1
Turbocharged
Found in:
2007/2008 Acura RDX
Displacement: 2,300 cc (140.4 cu in) [1]
Compression: 8.8:1 [2]
Power: 240 hp (179 kW) @ 6000 rpm (SAE net)
Torque: 260 lb·ft (353 N·m) @ 4500 rpm (SAE net)
Redline: 6800 rpm [3]
Bore: 86 mm
Stroke: 99 mm
[edit]K24
K24A4
[edit]K24A1
Found in:
2002-2006 Honda CR-V
Displacement: 2,354 cc (143.6 cu in)
Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
Compression: 9.6:1
Power: 160 hp (120 kW) @ 6000 rpm
Torque: 162 ft·lbf (220 N·m) @ 3600 rpm
Redline: 6500 rpm
[edit]K24A2
Found in:
2004-2008 Acura TSX
Compression: 10.5:1
Power: 200 hp (147 kW) @ 6800 rpm (2004-2005)
Power: 205 hp (150 kW) @ 6800 rpm (2006-2007) *SAE Net Rev 8/04
Torque: 166 ft·lbf (225 N·m) @ 4500 rpm (2004-2005)
Torque: 164 ft·lbf (222 N·m) @ 4500 rpm (2006-2007)*SAE Net Rev 8/04
VTEC Engagement: 6000 rpm
Redline:
Automatic 7100 rpm
Sequential Sportshift 7300 rpm
Manual 7600 rpm
[edit]K24A3
Found in:
2003-2007 Honda Accord (Europe(EDM)) and Japan(JDM)) and 2003-2007 Honda Accord Euro CL9 (Australia)
Bore and Stroke: 87 mm x 99 mm (3.43 x 3.90 inches)
Compression: 10.5:1
Power: 189 hp (140 kW) @ 6800 rpm
Torque: 164.5 ft·lbf (223 N·m) @ 4500 rpm
Redline: 7400 rpm
[edit]K24A4
Found in:
2003-2005 Honda Accord, 2003-2006 Honda Element
Compression: 9.7:1
Power: 160 hp (119 kW) @ 5500 rpm (166 hp in 2007/2008)
Torque: 161 ft·lbf (218 N·m) @ 4500 rpm (@4000 rpmin 2007/2008)
Redline: 6800 rpm
[edit]K24A8
Found in:
2006-2007 Honda Accord
Compression: 9.7:1
Power: 166 hp (124 kW) @ 6000 rpm
Torque: 160 lb·ft (217 N·m) @ 4000 rpm
Redline: 6500 rpm
2007-2008 Honda Element
Compression: 9.7:1
Power: 166 hp @ 5800 rpm
Torque: 161 lb·ft (218 N·m) @ 4000 rpm
Redline: 6800 rpm
[edit]K24Z1
Found in:
2007- Honda CR-V (RE3, RE4)
Compression: 9.7:1
Torque: 161 ft·lbf @ 4200 rpm
Redline: 6500 rpm
[edit]K24Z2
Found in:
2008 Honda Accord LX/LX-P trim models
Compression: 10.5:1
Power: 177 @ 6500 rpm
Torque: 161 ft·lbf @ 4300 rpm
Redline: 6800 rpm
[edit]K24Z3
Found in:
2008 Honda Accord LX-S/EX/EX-L trim models
Compression: 10.5:1
Power: 190 @ 7000 rpm
Torque: 162 ft·lbf @ 4400 rpm
Redline: 7100 rpm
Found in:
2009 Acura TSX
Compression: 11.0:1
Power: 201 @ 7000 rpm
Torque: 172 ft·lbf (MT), 170 ft·lbf (AT) @ 4300 rpm
Redline: 7100 rpm
[edit]K20A
Found in:
Compression: 11.7:1
Redline: 8400 rpm
Compression: 11.7:1
Redline: 8600 rpm
Compression: 11.5:1
Redline: 8600 rpm
Compression: 11.5:1
Redline: 8600 rpm
Compression: 11.5:1
Redline: 8800 rpm
[edit]K20A2
Found in:
Compression: 11.0:1
Redline: 7900 rpm
[edit]K20A3
Found In
2002-2004 Acura RSX
Compression: 9.8:1
Redline: 6800 rpm
[edit]K20A4
Found in:
[edit]K20A6
Found in:
[edit]K20Z1
Found in:
Compression: 11.0:1
Redline: 8300 rpm
[edit]K20Z2
Found in:
Compression: 9.6:1
Redline: 6800 rpm
Compression: 9.6:1
Redline: 6800 rpm
Compression: 9.6:1
Redline: 6800 rpm
[edit]K20Z3
Found in:
Redline: 8000 rpm
[edit]K20Z4
Found in:
Redline: 8200 rpm
[edit]K23
[edit]K23A1
Turbocharged
Found in:
2007/2008 Acura RDX
Bore: 86 mm
Stroke: 99 mm
[edit]K24
K24A4
[edit]K24A1
Found in:
Compression: 9.6:1
Redline: 6500 rpm
[edit]K24A2
Found in:
2004-2008 Acura TSX
Compression: 10.5:1
Redline:
Automatic 7100 rpm
Manual 7600 rpm
[edit]K24A3
Found in:
Compression: 10.5:1
Redline: 7400 rpm
[edit]K24A4
Found in:
Compression: 9.7:1
Redline: 6800 rpm
[edit]K24A8
Found in:
Compression: 9.7:1
Redline: 6500 rpm
Compression: 9.7:1
Redline: 6800 rpm
[edit]K24Z1
Found in:
Compression: 9.7:1
Redline: 6500 rpm
[edit]K24Z2
Found in:
Compression: 10.5:1
Redline: 6800 rpm
[edit]K24Z3
Found in:
Compression: 10.5:1
Redline: 7100 rpm
Found in:
2009 Acura TSX
Compression: 11.0:1
Redline: 7100 rpm
#38
I need a new engine on my Ep3 2002...If I buy the engine of a RSX base model..Will I have to make any modifications? Also can the manifold be swapped as they are different?.
#39
Actually I believe it'll bolt right up, their both practically the same motor, K20A3. I think the SiR in Canada uses the same motor if I last remember reading it on google and Honda forums a while back.
The intake manifold on the other hand I'm not to sure, so I'll say "maybe" just to be on the safe side.
Hope this helps bruh
#40
how much different are just the bare blocks?? could you just swap any k-series internals into any block? just wondering because i can get an a3 engine for cheap if not free, what a better way to start a build than with a free motor. ill most likely be talking to a local engine builder about this, just wondering what input the internet has.
#42
#44
1 Post
This thread is getting locked... as I know it ain't going nowhere...
Also if you want to know where you can buy a head or you want to buy a head take a look at the top of the page for the FS/WTB/WTT... you could post an add asking that you want to buy a head...
