Hesitation,Bog, Flat spot?
Hey everyone.
Just picked a 2004 Si with the HFP kit. 75K miles, STOCK besides a K&N drop in filter. My issues are mainly in 1st and 2nd gear. While accelerating between 2,000 and 3,000 rpms it will bog/hesitate, it feels like just stops making power for a second. No check engine lights, oil was just changed, spark plugs look newer (ngk iridiums). I ordered a new IAT sensor as the one in my intake tube looks bent, somehow. My next plans are to clean the IACV. I will be using my ultraguage to check tps percentages.. * The car is the same with a full tank of gas or with a 1/4* Any one have any input? This is so annoying to drive, my rsx was never like this.. Helps! Thank you Updates: *** The car seems to use extremely fast, 60 miles per first 1/4*** * The car is the same with a full tank of gas or with a 1/4* *Once warmed up, if rpms are held at 1500 or 2000 it misfires, sounds like a slow 2-step.. Thinking its ignition. 9/13- Cleaned IACV and adjusted the tps which is within perfect range... No difference.. Any help out there? |
Re: Hesitation,Bog, Flat spot?
TPS seems to act normal, but this is testing with an Ultragauge (same as scangauge) I will use my multimeter tomorrow.
if you're in neutral and hold the revs you can hear it missfire at that RPM?
Yes I can. But only sometimes. Neutral, rev to 1500 or 2000 and hold and there is usually a misfire.
*Also, sometimes the car idles high.. Clean the iacv? |
Updated!
Update with more info, someone has to have some input.
Wow i thought i was crazy but looks like im not the only one with this same problem. I get the same thing when i accelrate in 2nd gear right around 3k rpms. its almost like it sputters for a second nd then picks back up again.. It happens very inconsistently for me.
Im also having the same trouble with my gas. Once it goes under half a tank it seems to just evaporate lol I've also done all the maintance. Spark plugs, oil, new o2 sensor etc. |
I changed the IAT today because the one in there was bent lol. Drives a tad better, now idles like crap. This is annoying!
I have the same type of problem when cruising around 3k it bogs for a second and hesistates. Tried all different gas stations thinking I got a bad batch of gas. I know my TPS is good it was just replaced and no other CELs. Only does it once the car warms up.
Its annoying I'm in for an answer also |
Any thoughts on the Coolant Temp Sensor?
I am also having the same problem, car now has 163k and haven't replaced anything yet , just thought it was how the car drove with the "ivtec" , any thing I could start by doin to maybe fix the problem?
Originally Posted by b18bye
(Post 47867192)
lol this is funny as fuck becuse i usto own a 2002 civic si .. and from 1st to 2nd it usto misfire and since i had no cat and no resonator it would back fire from the exhaust ... we never could figure out what it was... and i sold it... but i had the same issue with my car.. miss fire hesitation and backfiring !!!
the flat dead spot betwee n2k and 3 k rpm THE FUCKING PRIMARY 02 SENSOR TROWING NO CEL CODE
A REAL MOTHER FUCKER CHANGE IT EVERY ONE WHO EXPERIMENCE A DEAD FLAT SPOT BETWEE N 2K AND 3K RPM the fucker primary 02 |
Originally Posted by ehrkeith
(Post 47863754)
