NO POWER AT ALL PLEASE HELP!!!
Ok i know this isn't our kind of car but i am reposting this for a friend. He has a nissan Spec v. Any ideas or solutions would be greatly appericated.
Well I pulled the engine to paint the engine compartment and when putting back in installed an ssr turbo kit with an safc2. Long story short made sure everthing was buttoned up all fluids were good, put the battery in and everything, even the safc was keying hot and powering properly. When I tried to crank it sounded like there was not enough power to turn it over so i hooked up a jumper box to give it that xtra kick and boom everthing is dead as in absolutly no power not even the door dinger. Checked all under hood fuses and relays and under dash fuses, and they are all good. power is going to and thru the fuse box and to starter. im stumped ! Any help or suggestions would be great. Thanx.
Re: (TarProductions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TarProductions »</TD></TR><TR><TD CLASS="quote">Could this be happening because we didnt sand the paint underneath the grounds?</TD></TR></TABLE>
you think?
you think?
Re: (sleepinEP3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepinEP3 »</TD></TR><TR><TD CLASS="quote">
you think?</TD></TR></TABLE>
Ahaha, gotta' love Honda-Tech sarcasm.
But anyway, you aren't conducting to ground through paint, chief.
Scratch that ****, and you should be good to go.
- Derek
- Derek
