Finally got my first Type-R
#26
Re: Finally got my first Type-R
Nice Blue-Civic-Hybrid,
The Koni's and GCs are on the EP3 its an Si and not TypeR, but man what a difference. Todds top hats are stupid easy to adjust, but I am seeing some new things pop up on the horizon which are very nice. I have a long way to go, but the build is going nicely. I think I hit every issue possible from EPS shutting down due to a vacuum leak to wrong, incomplete or damaged parts. It definitely has been a great learning experience.
I'm sure those Koni's/GC's are phenomenal compared to what you had, I loved that setup on all my other cars. I'm still not ready to pull the trigger on Todds top hats, I might be getting a DC5R full tranny instead...heheh..
#27
I'm sure those Koni's/GC's are phenomenal compared to what you had, I loved that setup on all my other cars. I'm still not ready to pull the trigger on Todds top hats, I might be getting a DC5R full tranny instead...heheh..[/QUOTE]
Did some research on the trannys.. Stick with the euro trans ... shorter gears tons more fun... as far as my research goes what you have is the best....
Just a heads up on the Hardrace upper control arms... they are great, but rust is visible on the nuts and bushings after a month of use in GA ....
#28
Thanks Valter, I just installed my DC5 KW's and the Hardrace rear camber arms yesterday and now I need some DC5 tie rod ends. I just ordered some Hardrace ones, just waiting for them over here in the UK.
I will post up pics later this week. I sent you back a message!
#29
#31
After a month on the Hardrace upper control arms...
After alignment and pilot SS today = full of awesome!
Dont mind the pollen on the car... That's GA for you in the Spring...
#34
M-Factory LSD installed...
Yesterday I just got my M-Factory LSD installed, while the tranny was off I also installed a new Fidanza flywheel and Exedy stage 1 clutch.
My car is a complete riot to drive now, the LSD works amazing and it changes the car to something so much more.
K-Pro 4 is on the way after my Skunk2 intake manifold and 70mm TB install..
pics to follow...
pics to follow...
#37
K-Pro-4 installed and dyno tuned!
K-Pro 4 installed and dyno tuned by TDi-North here in the UK. I made all the power I wanted and the car drives great...except for a little jerkiness on very low throttle with the Skunk2 70 MM TB... I will work it out later...
Almost ready for the Ring!
#38
Damn just saw this congrats on owning your first type *R* looking mean what numbers did you hit? After kpro. Also had a question that intake manifold is it the same as the ep3 Si or nah. I know the jdm type R came with the RRC not sure about the edm type R though.
#43
Happy with results...
After that, enjoy driving her at SPa and the Nurburgring next month. The whole goal is to drive fast but safely around the Ring in a car I built myself.
Bucket list!
#44
Re: Happy with results...
As of right now, I'm happy with what she makes. All I want to do right now is fine tune my tires/suspension, get rid of my 2 rattles due to a larger diameter exhaust and maybe get some Recaros from a 30th anniversary CTR....
Bucket list!
Bucket list!
I just did Atlanta Motorsports Park and Road Atlanta... I can only imagine how much better Spa and The Ring will be with what the EP3 was meant to be aka no K20A3 POS ...
Good Luck and be safe!
#46
final preps for Ring
Well, I finally pulled the trigger on new tires for my Nurburgring trip, Eagle F1's on Subaru STi wheels on my Type-R.
I did a quick rattle can job with custom OEM Subaru Gold in a can so I could get the deep gold rather than the newish yellow gold.
Before the paint job:
#47
Now some pics on the car. I did have to use 5mm spacers all around due to the weird offset of the STi wheels.
I will be adding ARP extended wheel studs to the rear wheels only fairly soon due to the rear wheels are just nicking the rear lower trailing arm under heavy turning. It's just the inner wheel weight that is hitting, no big deal!
Now on the car...
Now on the car...
