Ep3 Turbo Help
I have an 2005 black ep3 very beautiful car and I love it
the motor is in perfect condition I will fit a turbo on it to make 550 hp on fully stock motor I will make a motor rebuild and the head will be full ferrea valves , manifold hand made like full race and I will play a little with the compression it will be daily drive car at 300-400 hp And on boost controller 550 hp + meth In my country Greece have plenty but all use Garret turbo 3076 / 3576 / 3582 GT and GtX I won't to make the difference and use a Precision turbo I have in mind only Gen 2 ball bearing PTE turbos 5558 / 5862 / 6062 In k20 I have seen problems in low rpm spooling this is a highly recommend motor so I won't to spool from 4000 -5000 and have power until the 9k rev red line if any have the same setup please also share with me the rpm spool In my setup I will use max 1.1 bar pressure And in daily mode low pressure 0.4-0.5 Sorry for my bad English |
Re: Ep3 Turbo Help
Full spool is usually achieved earlier than redline of course. Depends a lot on your controller, BOV and wastegate, but you'll see full pressure around 3500-5000 rpms at wide open throttle..
Re: Ep3 Turbo Help
Originally Posted by thisguyaves
(Post 51747634)
