engine pull question
Re: engine pull question (gurlracer_camille)
I was going to drop the sub frame and head off then drop it out the bottom, but if it can be pulled from the top, I have a bit more confidence.
Re: engine pull question (bryse68)
IF YOU CAN LIFT YOUR VEHICLE AT LEAST 3FT HIGH THEN IT IS POSSIBLE TO DROP THE ENGINE FROM THE BOTTOM. YOU WILL NEED A SMALL DOLLY TO PUT UNDER THE SUBFRAME AND ROLL THE WHOLE SUBFRAME, ENGINE, TRANS OUT TOGETHER. CAN BE BOUGHT AT HARBOR FREIGHT FOR $22.00. I WORK FOR THE ACURA DEALERSHIP AND IT TAKE ME LESS THAN 1.5HR TO REMOVE THE ENGINE FROM THE BOTTOM. REMOVING FROM THE TOP IS NOT THAT BAD, EXPECT VERY BAD CLEARENCE AND PATIENCE TO DEAL WITH THE PROBLEM YOU WILL RUN INTO WHEN ON IT WAY UP. TAKE YOUR TIME AND DON'T RUSH BECAUSE YOU CAN DAMAGE THE RADIATOR, BRAKE MASTER CYLINDER, AND ACCESSORIES THAT MAKE GET TANGLE UP WITH THE MOTOR.
Re: engine pull question (AcuraTech23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraTech23 »</TD></TR><TR><TD CLASS="quote">IF YOU CAN LIFT YOUR VEHICLE AT LEAST 3FT HIGH THEN IT IS POSSIBLE TO DROP THE ENGINE FROM THE BOTTOM. YOU WILL NEED A SMALL DOLLY TO PUT UNDER THE SUBFRAME AND ROLL THE WHOLE SUBFRAME, ENGINE, TRANS OUT TOGETHER. CAN BE BOUGHT AT HARBOR FREIGHT FOR $22.00. I WORK FOR THE ACURA DEALERSHIP AND IT TAKE ME LESS THAN 1.5HR TO REMOVE THE ENGINE FROM THE BOTTOM. REMOVING FROM THE TOP IS NOT THAT BAD, EXPECT VERY BAD CLEARENCE AND PATIENCE TO DEAL WITH THE PROBLEM YOU WILL RUN INTO WHEN ON IT WAY UP. TAKE YOUR TIME AND DON'T RUSH BECAUSE YOU CAN DAMAGE THE RADIATOR, BRAKE MASTER CYLINDER, AND ACCESSORIES THAT MAKE GET TANGLE UP WITH THE MOTOR.</TD></TR></TABLE>thanks, I work at a honda dealership, and we pull it from the bottom but on a lift so its different than doing it at home. this helps alot
