nsx specs???
nsx specs???
was wondering if you guys have the specs for the motors of different years and tranny specs of the nsx. im talking crank sizes/bores/ compression/ etc... or has nobody posted a spec thread yet on the NSX forums yet? just wondering...if it has been posted can someone sticky that up so we can find it quickly thanks.
Re: nsx specs???
just curious but does anybody know anything about the engine dimensions of different years of the NSX in the NSX forum? i find that kinda sad......
Re: nsx specs???
http://www.geocities.com/NapaValley/1269/ns-spex.html
http://www.nsxprime.com/wiki/Model_Information
http://atdp.berkeley.edu/9931/dfan/nsxspecs.html
http://www.nsxprime.com/wiki/Model_I...n_Countries.3F
http://en.wikipedia.org/wiki/Honda_NSX
Re: nsx specs???
i could have gone to google i understand that..but the point i was trying to make was that this is hond-tech...and the other forums for preludes/integras...etc. have sticky's on all the specs of the motors and what not. its just handy and makes it easy to find. i was wondering why the NSX forum didnt have that. i could just copy and post it on here for you guys..but thanks for the short cut for the specs on the NSX that you posted.
Re: nsx specs???
by the way those websites you gave me didnt give me what i was asking for. Let me explain again. I was wondering if you had the engine specs...meaning dimensions...BORE size/CRANK sizes/ ROD lengths etc.... you get what im saying? it did have one good piece of info though..about the 91 blocks use iron sleeves. thanks again. If anyone can get some info on the block specs that would be great :D
Re: nsx specs???
About ten more seconds on Google produced this:
C30A:
bore - 90mm.
rod length - 5.986 in.
C32A:
bore - 93mm
The term "crank size" doesn't mean anything. What are you trying to ask - the weight? Journal diameter? Length from end to end? Stroke?
If you were trying to ask the stroke, its 78mm.
C30A:
bore - 90mm.
C32A:
bore - 93mm
Re: nsx specs???
thanks...thats what i was looking for. the stroke. so all NSX years have the same stroke? man somebody should post all the specs like that about the NSX and make it a sticky just for info purposes. but thanks anyway.
Re: nsx specs???
1GreyTeg
Acura NSX
02-26-2006 11:11 AM
