injector size
In need to find out the exact size of the nsx's injectors please. I have a set in my car right now and have to know the size to get a chipped ecu.
Re: injector size (neil23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neil23 »</TD></TR><TR><TD CLASS="quote">In need to find out the exact size of the nsx's injectors please. I have a set in my car right now and have to know the size to get a chipped ecu. </TD></TR></TABLE>
Somewhere around 240cc/min. Do a search on nsxprime. |
Don't buy a chipped ECU from anyone who doesn't know enough about the car to know the stock injector size. (Its 240cc) Also, chipped ECUs in general are not a good way to go. If you have basic mods, I would recommend getting an AFC, installing it, and spending an hour on the dyno tuning it exactly for YOUR car. I have done a couple of nsx's this way and it works fine. Also, you can re-tune when/if you do more mods. The only downside is that, on some nsx's, the ECU will try to compensate for the changes over time and you need to re-set it. I install a simple battery cut-off like classic car guys use and it works fine. Just kill the battery every few weeks and the ECU re-sets to the baseline sttings. My .02 |
