Why did my rotor screw come loose?
Old 11-30-2002, 12:10 PM
New User
gsrvx's Avatar
Default Why did my rotor screw come loose?
This has happened to me twice, where the distributor rotor screw came loose. Car shut off in the middle of 3rd gear at 7Krpm. Opening the dist. I found the screw lodged in the leak cover and finally the rotor couldn't spin. Why is this screw coming loose?
BTW, do I absolutely need a leak cover? It was damaged...so I took it out for now. I know I have a spare somewhere...just gotta find it.
-Rod
Old 11-30-2002, 12:39 PM
Racebrewer's Avatar
Default Re: Why did my rotor screw come loose? (RK)
Possible bad distributor bearing causing lots of additional vibration. Shakes the screw out. Get distributor checked ASAP as it can cause other damage if it seizes.
John
Old 11-30-2002, 12:57 PM
New User
gsrvx's Avatar
Default Re: Why did my rotor screw come loose? (Racebrewer)
It's happened with two different housings...so I must really bad luck with the "bearing". How can I get it checked out?
-Rod
polyhonda
09-05-2008 01:50 PM
ijjz
11-28-2006 04:47 AM
Truman001
05-30-2006 06:07 PM
az17xscrub
14
07-27-2003 10:30 AM
gsrvx
06-07-2002 01:17 PM
Quick Reply: Why did my rotor screw come loose?
