Tranny OIL: OEM Honda vs Redline
Old 09-27-2002, 04:23 PM
Hard2Find's Avatar
Default Tranny OIL: OEM Honda vs Redline
which one would you guys prefer?
OEM Honda MTF
or
Redline
Old 09-27-2002, 04:32 PM
I shoot brides
yoshi234's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (Hard2Find)
i've never tried redline, but j00 can't go wrong w/ what the factory uses.
Honda trans oil
Old 09-27-2002, 04:33 PM
Mr.Sha007's Avatar
redline.
i will be selling redline products in a week or so. send me an email:
sales@areteauto.com
98itR484's Avatar
Honda MTF
I had Redline in my car for the first 15k miles, but my 2nd to 3rd started to grind, the infamous synchro problem ever since then ive been running honda mtf (10k miles)
Old 09-27-2002, 05:01 PM
sackdz's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (Mr.Sha007)
redline.
sales@areteauto.com
o my, what great feedback! That's a great reason to go redline.
Old 09-27-2002, 05:22 PM
B2FiNiTY's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (sackdz)
Honda is good enough for me.
Old 09-27-2002, 05:23 PM
FSAE
92TypeR's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (ExOdy)
I use Honda MTL.
However, I havn't heard anything bad about Redline.
Old 09-27-2002, 05:32 PM
big strong guy
rainmanEK's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (92TypeR)
i honda mtf! eric
Old 09-27-2002, 06:04 PM
rodimus's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (rainmanEK)
HONDA MTF has additives that are vital to the operation of your honda
tranny/synchro's.
redline's products are 2nd to none...but when it comes to tranny oil for your car..
stick with the HONDA MTF.
the only other comparable that i know of is the GM synchroshift or something...
(used in the corvette)
Old 09-27-2002, 06:15 PM
Honda F1's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (EVOL)
Add GM Syncromesh to the list as well. Heard it can clear up or minimize some minor synchro issues.
Old 09-27-2002, 06:19 PM
Global Moderator
Reid's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (Honda F1)
Honda MTF.
Old 09-27-2002, 06:22 PM
VTECPWR's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (Reid)
Redline. When I switched from Honda to Redline the difference was like night and day. It shifts much smoother and the smoothness lasts longer than with the OEM stuff.
Old 09-27-2002, 06:25 PM
kkim's Avatar
I use redline and have no problems. 12k miles with it in the R.
Old 09-27-2002, 06:39 PM
Big Teggie's Avatar
I have been using the GM Syncroshift in my ITR trans for about 6k miles since I have had it, before and after a rebuild. Shifts were always very smooth, and never had any problems. Recently I put in Honda MTF becuase I didnt have time to go to the GM dealer. I like the the GM stuff better, it seems to be a little bit smoother.
I have also heard it will help out small grinds. But you cant expect fix a totally shot snycro problem.
Old 09-27-2002, 06:53 PM
PrecisionH23a's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (VTECPWR)
The difference from night to day could be because your stock honda oil was old and dirty...
Old 09-27-2002, 08:27 PM
B16CRX's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (GudeH23a)
I always use Honda MTF. I don't know from experience, but what I have heard is Honda trannys don't like anything other than Honda fluid.
Old 09-27-2002, 08:38 PM
TREVER's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (B16CRX)
honda is the best, mobil one 10-40 is next
Old 09-27-2002, 09:20 PM
Kengs's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (TREVER)
This stuff works great for me:
HKS FF Gear
Old 09-27-2002, 10:21 PM
Bbasso's Avatar
I'm sorry to say but metal does not 'just' repair its self.
As for the Gm fluid it migth have better properites then Honda's but as for fixing small problems= horseshit!
Do I need to elaborate?
Old 09-27-2002, 11:09 PM
lucas569's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (Bbasso)
yes, please do. i was told told by an acura tech to try gm synchroshift before i tore my tranny apart when i was using clean honda mtf, i was getting the infamous 3rd gear scratch at 8400 rpm upshift. used the gm stuff and viola! scratch dissapeared!
Old 09-27-2002, 11:34 PM
TREVER's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (lucas569)
what was in your trans. before, and how long was it in there? I also know Acura tech(s) and they don't recomend any gm fluid in a h/a trans.
If any bandaid fluid creates the illusion of a repair, have you also considered long term bearing damage?
Old 09-27-2002, 11:43 PM
New User
TaboR's Avatar
To me Honda MTL is not as good as GM oil.
me fucked up my synchro by KAAZ oil. (hard to get in 1st gear& grind when 2nd~3rd red line shifting)
then change back to Honda MTL plus some 8 dollar tranny fix fluid (cant remember the name ). walala..... same **** happened but much smoothier however.
now~ GM oil by itself. Not fixed, but much much easier to get in the first gear
and no grinding under any condition~
Old 09-28-2002, 01:39 AM
JDMb18civic's Avatar
thas wut i heard too
well i use OEM honda MTF
VitaminB20's Avatar
Location: Where the grass is green and the girls are pretty.
Default Re: Tranny OIL: OEM Honda vs Redline (FreddyR)
OEM
Old 09-28-2002, 02:23 AM
Cyber ITR's Avatar
Default Re: Tranny OIL: OEM Honda vs Redline (VitaminB20)
sorry for my ignorence
but what is GM oil ?
Quick Reply: Tranny OIL: OEM Honda vs Redline
