SMS ITR 2.5" Exhaust Installed
Went to SMSP yesterday to help Dave test fit and install his new 2.5" cat-back exhaust system on my car. We have been discussing a design that would be fairly quiet, free-flowing, and adjustable in length to accomodate header adjustments. Here are some pics and narratives.
Dave is a Magnaflow dealer so we used an oval can and resonator. We used mandrel bends to construct the entire exhaust system.
Magnaflow 2.5" Center/Offset can was used.
Here is looking into the can. We used an offset to help keep noise down just a bit. Still pretty straight thru as you can see.
Here is the completed exhaust in sections. The adjustable insert, B-pipe, and can. I showed it this way because once it is painted flat black with heat paint, you can't see much.
Here is a closer look at the adjustable B-pipe. We use a collar to clamp the exhaust. Currently we have about 2'-2.5' of overlap. We did it this to allow enough piping to remove the cat and extent it to the header. Instant test pipe. This of course is designed so that when I tune the length of the header and the exhaust can lengthen and/or shorten with my needs.
Here is final product! We used my OE tip to finish off the look.
Here is the B-pipe.
Here is what the unknowing prey see!
The exhaust is a bit louder than stock under acceleration. It actually gets quieter the higher up the rpm band I go. It is still elevated at cruising(highway) speeds, but not nearly as bad as many exhaust out there I've heard. My girlfriend approved it!
Performance wise....wow! My modified OE exhaust was a real hinderance I have found out. See below pic. Power has increased substantially across the board. Words can never do it justice! I will be dynoing in 2 weeks.
Dave is out of town until Thursday, so please be patient with responses! He has plans to possibly manufacturer the B-pipes as a single piece along with custom can possiblities. He DOES NOT have pricing available yet for this unit. Please let him know about your interest.
[Modified by RStoR, 7:20 PM 7/1/2001]
[Modified by RStoR, 7:25 PM 7/1/2001]
Here is the B-pipe.
Re: SMS ITR 2.5" Exhaust Installed (RStoR)
I really like the stock look... you failed to metion what it sounded like at idle.
I'll shoot Dave an email when he gets back... I'm interested...
Re: SMS ITR 2.5" Exhaust Installed (itr501)
Looks great! Are all of the components stainless? I see that the stocker that you swapped out already had the restriction at the cat flange removed. And you still noticed an improvement? Very cool.
New User
Re: SMS ITR 2.5" Exhaust Installed (8400-RPM)
personally every magnaflow used in conjunction with a presilencer that I have heard sound great nice and mellow no raspyness at all.
Re: SMS ITR 2.5" Exhaust Installed (kengs)
Zeus~
Since I'm running Spec B's the idle sound is very deep and lumpy. I've heard a Tanabe & N1 set-up with these cams and this set-up matches that. It isn't deafening, but at a stoplight it's very obvious that the car isn't stock. As the exhaust note climbs, there is no raspy sound as with the JDM set-ups I mentioned. Only a deep note or at least as deep a note as a 4 banger can have!
2kbill~
My set-up uses a combination of mild steel and 409 stainless. After reviewing cost with Dave, I chose to go with these materials. That is why we used the high-temp paint, ie. rust prevention and slight scavenging benefits. If the manufactured B-pipes go into production, then I'm sure SS will be utilized throughout.
PS~
After removing my OE axle-back we discovered that piping reduces to about 2" to the can. That means, even though I modded my B-pipe with the 2.5" with transition adapter to 2.25", I still had major restriction the axle back.
[Modified by RStoR, 10:24 PM 7/1/2001]
2kbill~
PS~
Looks good man. Wish I had a quieter exhaust sometimes. But I know that the Spec B's are gonna love my exhaust when I get them.
James
James
definitely a sweet setup...I've already expressed my interest, and I'll do so again...can't wait till he makes me one!
I said I don't want a title!
Re: SMS ITR 2.5" Exhaust Installed (Todd00)
Todd00~
There are actually 3 major restrictions in the OE cat-back. The two you mentioned at the the cat/B-pipe connection and at the can, as well at the cat-back/axle-back connection. This connection actually reduced to under 2". My point was, the axle-back is not 2.25" piping as most people think. It is only 2". With the entire OE cat-back off, the reduction in size to the B-pipe was obvious. Hope that clarifies it.
Re: SMS ITR 2.5" Exhaust Installed (typeR158)
Schweet!
My fiancee owes me, so after I recover financially from my wedding and getting my car back on the road, I'm looking to a full SMS exhaust from Header back
FB
FB
