Scheming and Plotting: How my car will end up.
Over the past couple of weeks, steps have been taken that will ensure the coming of one of three things: My primary objective, my acceptable secondary objective, and a third objective which is unacceptable. Each of these has been labelled Plan A, Plan B, and Plan C respectively. I will outline each of them for suggestions, discussion, and general flaming. But first, a few words explaining this whole thing.
A few words explaining this whole thing. I got the idea some months ago that I was going to build a car specifically to run my favorite terrain: mountain roads. I fought with myself about how to most effectively do this and finally came to a few conclusions. I will tune the car with drivability and response being the primary goals so the plan is to go with an all motor buildup. Handling and weight have already been addressed, I have a good set of seats and will be installing a roll bar and appropriate harnesses in the upcoming months. I will attempt to source a set of Advan Neova AD07 tires to keep everything as sticky as possible without sacrificing wet weather control. This leaves me with the engine being the only major decision, so I decided to sell it. Plan A My primary objective will be to source a JDM K20A from the DC5 Integra Type R and swap it in. The increased power and torque of this engine should greatly help me on my quest to build a mountain munching machine, and when only mildly tuned, K20's are producing amazing power and superb responsiveness. Not to mention the shorter gearing and the additional sixth gear. Plan A is to install a K20A and tune it mildly. Plan B Assuming something goes wrong, I will be left with no choice but to return to the B series. If I do so, it will be with an LS/VTEC setup running high compression, crazy cams, ITB's and a JDM ITR tranny. Basically nothing new or exciting, just fast. Plan B is to build an all motor B series monster. Plan C Being that my stock engine is already sold and will be coming out soon. I had to source a temporary engine. Fortunatly for me, the buyer of my engine happens to have a spare engine just laying around that will do well in serving the purpose of a temporary engine. It's a bone stock 93 Honda Civic CX engine. I've always had thoughts of creating the "best gas milage ever" Type R and assuming I get robbed, or have to pay for something outrageous, then this is the route I will go. I really don't want to do this, as it would kill the spirit of the car. Plan C is to build a Type R to have the best gas milage possible using a stock CX engine and tuning. As you can see, Plan A is really cool, Plan B is alright, and Plan C sucks. I just thought I would take some time and inform everyone as to my decision. The estimated date of completion for Plan A is set for June 20, 2004. |
Re: Scheming and Plotting: How my car will end up. (Kendall)
Turbo the CX. https://honda-tech.com/forums/images/smilies/emwink.gif
Re: Scheming and Plotting: How my car will end up. (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">Turbo the CX. https://honda-tech.com/forums/images/smilies/emwink.gif </TD></TR></TABLE>
Somehow, this idea is very tempting. |
good plan....
plan c sounds retarted.. unless you're low on money.. but if you're low on money, whats the point of doing k20a swap in a first place.
if money is an issue, is cheaper to stick with b series.. - what i'll be doing for a while.. but eventually i wouldn't mind moving to k20.. hondata looks bright for k series. either way, good luck with everything! looking forward to seeing how everything turns out. |
Re: Scheming and Plotting: How my car will end up. (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">plan c sounds retarted.. </TD></TR></TABLE>
is it me, or does the whole idea sound retarded? a roll bar for mountain driving? the expense of putting a k20 in a dc2? mountain driving in florida?! |
Re: Scheming and Plotting: How my car will end up. (magic hat #9)
a cx will not result in the best mileage type r. it will result in the slowest type r ever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 »</TD></TR><TR><TD CLASS="quote">mountain driving in florida?!</TD></TR></TABLE>
I live in NC for most of the year. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider »</TD></TR><TR><TD CLASS="quote">a cx will not result in the best mileage type r. it will result in the slowest type r ever.</TD></TR></TABLE> That it will. |
I like plan A. If everything can be fitted properly, a DC2 chassis with the much improved K20A motor would be the ultimate integra. Slap on that toda cam/ecu kit and you are looking around 220whp.
here's the best idea.....
plan d) Buy my JDM R motor thus giving me the rest of the needed cash to secure a K20 swap and enough cash to put it over the 260whp mark and put it in my teg. Then, to show how cool you are, I'll put a HUGE picture of you on the side of my car, and a quote that says "PoweRed by Kendall" |
i say A, if your low for money then turbo plan c:)
is it me, or does the whole idea sound retarded? </TD></TR></TABLE> |
Re: Scheming and Plotting: How my car will end up. (Dr Pooface)
CX engine in an ITR?
I want some of what your'e smoking... https://honda-tech.com/forums/images...s/emsmilep.gif I would just build up a B20 motor for n/a or bOOst - then you can make serious hp without having to re-engineer the whole car... (and saving some cash too). How much is the going rate for a K20 swap w/ everything? |
Build and boost the hell outta that ls/vtec!!! Plan A sounds very tempting as well, and as the majority have cleared pointed out.....C sux!!
Re: Scheming and Plotting: How my car will end up. (Philly_NBP_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R »</TD></TR><TR><TD CLASS="quote">
How much is the going rate for a K20 swap w/ everything?</TD></TR></TABLE> K20 Eg told me about 8500 Everything Installed Dc5-R or Just a Type-S minus 1600 |
Re: Scheming and Plotting: How my car will end up. (96 Ls lnTeG)
ouch.
I would build a B20... |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R »</TD></TR><TR><TD CLASS="quote">I want some of what your'e smoking... https://honda-tech.com/forums/images...s/emsmilep.gif</TD></TR></TABLE>
They're made in Cuba and sell for about $15 each if you can find any. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 Ls lnTeG »</TD></TR><TR><TD CLASS="quote">K20 Eg told me about 8500 Everything Installed Dc5-R or Just a Type-S minus 1600</TD></TR></TABLE> There's a group buy on http://www.k20a.org for $5500 for the engine and all necessary components, plus $1750 for everything needed to get it running in a DC or EG chassis. After adding some money for peripheral parts, fluids, etc, I plan on having about $8000 invested in it. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R »</TD></TR><TR><TD CLASS="quote">I would build a B20...</TD></TR></TABLE> But there's just so damn many of them, it wouldn't be original. |
K-series requires the use of a cable shifter.
Cable shifters suck ass. |
