sorry its about oil again
I see everyone useing Mobil1 right?
and all my friends around me they usein mobil1 for Rs
and Im useing motul 300v poweracin 5w30 since feb
Im not asking which one is better, I was just doubt about Oils
are they really different by the oil names(company)
5w30 is it all the same things(oil)?
the numbers(5w30) is the codes of how thickness is right?
if it isn't all same how,why,what?
sorry for gloomy questions
my knowledge just ended need your helps
New User
Re: sorry its about oil again (DJHan)
Not this 'ol chestnut. LOL
I reakon it up to you..... well your car anyway.
I use Mobil 1 0w-40 in Sydney, Australia temp are from near 0 to 40 degrees C.
It was run-in properly, Dino oil changed at 2,000 KMS the 5,000 KMS at 10,000 KMS it got the good stuff, Tri-Synth.
It doesn't use any oil between oil changes ( every 10,000 KMS) unless we go to the track, then my baby only need a small top-up, maybe 50-100 mls ( a mouth full ). Currently up to 46.500 Kms approx.
But some folks can't use this oil because it's too thin. Either that, or the guys who put my motor together were right-on-it and did a top job.
It doesn't mater you me, as Mobil run a BMW for 1,000,000 KMS on this oil ( probably with regular oil changes) than took the parts out and measured them, they were all within Spec's for New parts. 1 million kms with no wear.....
That'll do me.
Later.
That'll do me.
Later.
Re: sorry its about oil again (George Knighton)
hey man whats up oil is oil brand dosent really make a difference the only thing that matters is the sae and api rating as long as those are all good if it has both of those stamps on it you'll be all good brand dosent mean **** chevron oil is just as good as what ever you match it up to just check the api and sae rating
H23vtecEG
04-14-2003 07:40 PM
