Rear wheel bearing, Torque Spindle nut to 132??
Old 07-13-2003, 06:55 PM
New User
BrandonClaps's Avatar
Default Rear wheel bearing, Torque Spindle nut to 132??
In the helms is says to torque the spindle nut to 132, when i did that it was very hard for the bearing to turn, not as easy as the other side. Will it burn up the bearing, or what should i do? I loosened it till the bearing would spin like the other side (passenger side is from factory, i replaced the driver side)
the reason i ask this is because the helms said 132, and also when i hit little bumps my car seems to sway side to side
Old 07-14-2003, 12:15 AM
New User
Default Re: Rear wheel bearing, Torque Spindle nut to 132?? (BrandonClaps)
ttt
Old 07-14-2003, 06:00 AM
New User
Old 07-14-2003, 09:35 AM
Track rat's Avatar
Default Re: (BrandonClaps)
I'd go with the published torque spec. The bearing will likely loosen up in time, and then feel the same as the older one on the other side.
You may have other problems that are causing the sway. My guess is that if you are replacing a wheel bearing, you must have had an "incident". Perhaps you also knocked it out of alignment, blew a strut, bent the spindle, or bent a trailing arm.
Old 07-14-2003, 01:53 PM
baonest1's Avatar
Default Re: (Track rat)
hmm, the other day i replaced the hub on my aerostar.. the front wheel (its RWD). i had it tightened to much, i dont know the torque spec of it. but one of the mechanics at work told me that its too tight cuz it wouldnt spin freely on the lift. so we tapped it loose until it spun, and it was still tight enough on there.
id check with honda/acura on this one.
Old 07-14-2003, 09:11 PM
New User
Default Re: (baonest)
honda said 134 so i was off by 2 (bad memory) but still it seems hard, i wonder if i a tech would torque it to 134, and then see how tight it is and back it off grrrrr confusing
Old 07-14-2003, 09:44 PM
baonest1's Avatar
you can try to take it to honda or wherever, but they will write up a ticket and charge you. that is what sux about honda. you cant get any info out of them unless you pay $$
Old 07-16-2003, 07:17 AM
Track rat's Avatar
The bearing design of a RWD Aerostar and a Honda are totally different! Do 134 lbs like Helm says and bend the locking tab on the nut too!!
scruffyduck
Honda S2000
02-21-2012 04:38 PM
eastbayrep
02-04-2010 09:38 PM
kevin22trac
05-09-2008 10:00 AM
hawaiiangsr
11-21-2006 12:36 PM
Greyout
12-03-2001 07:28 PM
Quick Reply: Rear wheel bearing, Torque Spindle nut to 132??
