Need a quick favor from an ITR Owner...A Measurement .....
Please.....I need a huge/simple favor from an ITR owner.
I need to know what the measurement from bolt to bolt is on the rear inner ITR Trunk strong bar. Thanks, -Jeff https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: Need a quick favor from an ITR Owner...A Measurement ..... (Outkasted24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outkasted24 »</TD></TR><TR><TD CLASS="quote">rear inner ITR Trunk strong bar.
</TD></TR></TABLE> The who? What? Rear strut tower bar? Or that thing all the way at the back of the trunk? |
Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut »</TD></TR><TR><TD CLASS="quote">http://www.geocities.com/bretq....html</TD></TR></TABLE>
Sorry, this site is temporarily unavailable! The web site you are trying to access has exceeded its allocated data transfer. Visit our help area for more information. |
Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">Sorry, this site is temporarily unavailable!
The web site you are trying to access has exceeded its allocated data transfer. Visit our help area for more information. </TD></TR></TABLE> I just clicked on it, and it's fine. Your mom still have that filter set on your browser? https://honda-tech.com/forums/images...s/emsmilep.gif j/k |
Re: Need a quick favor from an ITR Owner...A Measurement ..... (Chris F)
The who? What? Rear strut tower bar? Or that thing all the way at the back of the trunk?</TD></TR></TABLE> Yes, The OEM silver bar that is bolted inside the trunk to the frame,....Right under the taillights. I need the measurement from bolt head to bolt head. P Nut, I read all 4 pages of the DIY link, But didn't see the info I'm looking for. The Geocities link is dead. Thanks for trying though https://honda-tech.com/forums/images/smilies/emwink.gif -Jeff |
you will need to drill two holes aproximately 91cm apart
Isn't that what you were looking for? |
I don't know what's wrong with your computers, but here's BSQ's insturctions...
DIY trunk brace Disclaimer - please read. Here are the necessary parts from Home Depot for the trunk brace (see figure 1 and figure 2): 1" square x 4' long steel bar ($8.44) 1" square black plastic end caps (4 in a bag @ $0.85) 5/16" x 2.5" long stainless steel screws (2 needed @ $0.69 each) 5/16" ID x 7/8" OD stainless steel washers (2 needed @ $0.07 each) 5/16" ID x 7/8" OD zinc washers (4 needed @ $0.03 each) 5/16" ID x 1.5" OD zinc fender washers (2 needed @ $0.11each) 5/16" ID x 7/8" OD rubber washers (3 in a package @ $0.33) 5/16" nylon lock nuts ( 2 in a package @ $0.97) *** TRUNK BRACE KIT IS NOW AVAILABLE FOR PURCHASE *** (please visit http://www.geocities.com/bretq....html for further information) Here are the steps for installing the trunk brace: 1.) Cut the 1" square bar stock to 36.25" (same length as Type-R trunk brace). 2.) Drill a 3/8" hole in both ends of the 1" square bar (approx. 0.4375" front the end of the bar) (see figure 3). 3.) Remove the plastic rear trunk liner (see figure 4). 4.) Center the bar equally on both ends and mark the mounting holes on the sheetmetal. 5.) Drill a 5/16" hole in the rear trunk sheetmetal (inner and outer sheetmetal / both mounting holes) (see figure 5). 6.) With a thin paint brush, prime the new mounting holes. 7.) Determine the mounting location on the plastic rear trunk liner and drill 1" hole in the liner (figure 6). 8.) Reinstall the trunk liner. 9.) Install the black plastic end caps on the steel bar (see figure 7). 10.) Place a stainless steel washer on 2.5" long bolt, then insert bolt through the hole in the bar. Repeat on other end of the bar (see figure 8). 11.) Place 2 zinc washers on the bolt. Repeat on the other bolt (see figure 8). 12.) Insert both bolts into the new mounting holes (see figure 9 and figure 10). The remaining steps may require an additional person 13.) From underneath the car, insert a rubber washer on the end of the bolt. Then insert a zinc fender washer on the bolt. The rubber washer is used to seal the hole from moisture. 14.) Thread the nylon washer on the bolt and then tighten. Repeat on the other end of the bar. Warning: do not over tighten the nuts. Figure 1 Figure 2 Figure 3 Figure 4 Figure 5 Figure 6 Figure 7 Figure 8 Figure 9 Figure 10 Nedstat Basic - Free web site statistics Yahoo! GeoCities Yahoo! GeoCities |
Yes, The OEM silver bar that is bolted inside the trunk to the frame,....Right under the taillights. I need the measurement from bolt head to bolt head. P Nut, I read all 4 pages of the DIY link, But didn't see the info I'm looking for. The Geocities link is dead. Thanks for trying though https://honda-tech.com/forums/images/smilies/emwink.gif -Jeff </TD></TR></TABLE> I can take a measurement for you... https://honda-tech.com/forums/images/smilies/emthup.gif brb Edit, almost exactly 35" center to center. (about 89 cm.) Hard to measure exactly. Definitely not quite the 91 cm that was quoted above... Hmm! |
I can take a measurement for you... https://honda-tech.com/forums/images/smilies/emthup.gif brb Edit, almost exactly 35" center to center. (about 89 cm.) Hard to measure exactly. Definitely not quite the 91 cm that was quoted above... Hmm!</TD></TR></TABLE> Thanks Mang!!! https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emwink.gif |
Sure!
So, umm, why'd ya need that measurement anyway? |
just take out the rear plastic piece in your trunk, all integra's have the bolt hole's, itr's just get different rear plastic piece and the bar
Re: Need a quick favor from an ITR Owner...A Measurement ..... (01-0720)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 »</TD></TR><TR><TD CLASS="quote">just take out the rear plastic piece in your trunk, all integra's have the bolt hole's, itr's just get different rear plastic piece and the bar</TD></TR></TABLE>
That's not all true. I had a '99 Ls that I installed a (Real not DIY) ITR trunk bar in last year. I had to drill out the holes myself. The holes you are talking about are for the trunk cargo clips that come with ITRs only and are optional after purchase for any model Teg. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote"> Sure! So, umm, why'd ya need that measurement anyway?</TD></TR></TABLE> I was thinking about DIYing a ITR bar into my '00 Si. I have been after a Benen Strong bar for months now, But I think I'm luckier to find a ITR Trunk bar for sale then a Benen https://honda-tech.com/forums/images/smilies/emwink.gif |
