Need help with Headlight wiring harness!
My driver's side headlight keeps going out b/c one of the wires that goes into the plug you connect to the headlight bulb became loose and eventually came out. I tried to solder it on, and it worked for a while, but now it's officially fu*ked. Anyway, since the nearest Acura dealer is almost an hour away I was hoping I could pick one up from the Honda dealer in town. Are there any honda's that share the same harness as the integra? I think it's a 9006 for the low beam, and I would think there would be several cars with similar wiring harnesses. Anyway, the dealer told me they have no idea how to look up the right part number b/c they don't have an acura parts list on file (lazyness!!!). Anyway any help would be appreciated, I need this problem fixed is so annoying!
Re: Need help with Headlight wiring harness! (98Itr-0448)
I would go to the nearest junk yard w/ some wire cutters, and cut off the plug from the first integra you see, then solder it into your harness.
Wagonist
04-12-2016 01:39 PM
Ritchie
07-29-2006 02:34 PM
