Integra type r CAR WONT REV PAST 5800RPM huge problem
hey guys
B18c5 engine itr!! all stock , stock ecu etc... nothing major The other day car was fine reving 8700rpm with no problem . Today i was driving normal not floring the gas or nothing but when it hits 5800 for vtec engagment it blocks there and its doing noises like its a rev limiter it wont go past ..The engine breaks down rpm stay 5800 and rpm wont go past it ..like is rev limited there Does anybody have any idea what could cause the problem Fuel is all good i checked it ..ONe of my friend says it might be a distributor coil.. or distributor causing that problem cutting the engine at 5800.But again car is working fine in every gear till 5800 before vtec engagment?? does anybody have any clue what can i check to find whats causing it .. has anybody ever have this problem?? |
Re: Integra type r CAR WONT REV PAST 5800RPM huge problem
did you check your oil?
1 Attachment(s)
a blocked exhaust ...
sounds like ur oil pressure, check ur oil level as stated above
Your friends are right. Buy a new distributor and it will fix the problem
it might also be your spark plugs.
Is there a Check Engine Light on ? Oil level ?
There is no check engine on oil. I will check oil level but i know if the oil is low the head starts making clicking noises if not enough.. Thanks all for an input
Can i use A different distributor or does it have to be type r .. i mean Acura integra ls is there a difference ?what all distributors can you run on type r
Originally Posted by Allmotor-R
(Post 41615365)
It's most likely a fuel, or oil pressure issue. Had the same thing happen to me but I was also below E on the fuel level, and 5800RPM would hit like a rev limiter. The same thing will happen if there isn't enough oil pressure, VTEC will not engage.
or the vtec solenoid is having issues. it won't always cause a CEL either.
The oil pressure is good! oil level good. It has to be distributor!! my friend that had a type r motor had the same problem but then again ill check and then see if it is a vtec silenoid too..thanks for the input guys
