Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Acura Integra Type-R (https://honda-tech.com/forums/acura-integra-type-r-8/)
-   -   Injector Clip Retainer (https://honda-tech.com/forums/acura-integra-type-r-8/injector-clip-retainer-3383159/)
CWFL5CTR Dec 27, 2025 08:25 PM
https://cimg9.ibsrv.net/gimg/honda-t...682a652e5b.jpg
I believe I have Prelude VTEC injectors in my car and I would like to get rid of these bootleg zip ties that hold down the clips. Does anyone know where I can get them? I'm assuming there is a metal clip that would secure it down? Just curious what are these clips called? (e.g. EV1?) The injectors are Keihin. Any info is appreciated!
JRCivic1 Dec 27, 2025 08:57 PM
Re: Injector Clip Retainer
I am not sure you can buy just the metal clips for your fuel injector plugs... you will likely have to purchase a set of the fuel injector plugs and simply rob the metal clips from them and place them on your current injector plugs. Remember that you will need the same type of plugs to get the clips from... OBD-0 style metal retaining clips are slightly different than those found on OBD-1 grey style plugs.
CWFL5CTR Dec 27, 2025 08:59 PM
This looks like it could work?
https://www.ebay.com/itm/389188216200
CWFL5CTR Dec 30, 2025 04:34 PM
I talked to the seller and sent him some more pics. Evidently I have an OBD0 plug. From reading old honda-tech posts from the previous previous owner, it should have Prelude injectors. I made the assumption it was from a 92+ Prelude, which should be OBD1/OBD2 no?
This is what I bought: https://www.ebay.com/itm/38912608729...torefresh=true
JRCivic1 Dec 30, 2025 06:46 PM
Forget what year they are from... this does NOT dictate the OBD-X version. The plug style is milky clear in color, and this indicates an OBD-0 style. OBD-1 style injector clips are, with a couple of exceptions, grey in color. The link that you have referenced is one of those exceptions. Unfortunately, there is no photo of the BACK of the injector clips and how the metal retaining clip/lock is shaped. It MAY fit your current injector clips.
