how do you take out the speed limiter in the jdm p73 ecu?
Re: how do you take out the speed limiter in the jdm p73 ecu? (JinDIESEL)
any chips or kits to take it out?
my guess,is that you have to re-chip it. but being a 96+ecu, i can only think of two companies,mugen and spoon. i'm sure there is atleast one other companies out there.
Re: (esponet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet »</TD></TR><TR><TD CLASS="quote">my guess,is that you have to re-chip it. but being a 96+ecu, i can only think of two companies,mugen and spoon. i'm sure there is atleast one other companies out there.</TD></TR></TABLE>
hm.. i actually just wanted to use the stock ecu and just mod it.. like solder a wire here, clip out a resistor there, suttin like that.. |
Re: (JinDIESEL)
If you do want to chip it, check out this thread:
https://honda-tech.com/zerothread?id=947561 |
I thought the old Field SFC-Vtec could do that. Just speed limiter--not rev limiter, mind you.
Re: how do you take out the speed limiter in the jdm p73 ecu? (Todd00)
thanks doggi
I read in another thread that you would like to keep the stock program, but just disable the speed limiter. Does anyone know what would happen if the VSS input to the ECU were cut (or more elegantly pulled from the ECU plug)? The gauge cluster should be independent of the ECU. I have not tried this, but it may be an option.
If you cut the VSS wire to the ECU you will get a CEL, which means no vtec and a 6500rpm redline (safe mode)
There are a few simple ways, 1. get yourself an R-spec vtec controller (which usually come with a plug'N'play harness, this removes the speed limiter and allows the ECu to run stock, or 2. Get an Apex'i RSM which also removes the speed limiter and doesnt effect ECu settings...i have both on my JDM ITR!!!!! |
Re: (mugenracer)
wow good thing u mentioned that. where do you get these chips?
Re: (JinDIESEL)
actually, have you ever tried taking your car up to 180? Me and my friend is both using JDM P73 ECUs and both of us has been well into 200 km/h.....we did it just to test the 180 km/h limit....to our surprises, it just kept climbing. Pretty sure that my ECU is stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">I thought the old Field SFC-Vtec could do that. Just speed limiter--not rev limiter, mind you.</TD></TR></TABLE>
That is correct. |
Re: (Petah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah »</TD></TR><TR><TD CLASS="quote">actually, have you ever tried taking your car up to 180? Me and my friend is both using JDM P73 ECUs and both of us has been well into 200 km/h.....we did it just to test the 180 km/h limit....to our surprises, it just kept climbing. Pretty sure that my ECU is stock.</TD></TR></TABLE>
even better. i jz hope that the stock ecu will help me pass smog here since they dont have to connect to my ecu since it's a 95 version |
Just break off the pin on the cluster that stop the needle https://honda-tech.com/forums/images...s/emhammer.gif
