Condensation inside JDM front headlight.
I got some condensation inside my JDM headlight and dont know how to get it out. Obviously there has to be some way water is getting inside the headlight? How do i get the condensation out of it? Ill taking headlight out to see if i can see any crackes or a way water is getting in in the meantime.
1 Post
Re: Condensation inside JDM front headlight. (01_ITR)
A heat gun is a temporary fix, but you'll need to reseal it to fix the problem permanently. Use caution when using a heat gun not to melt the lens. Make sure you give the lens a break not to get too hot and you should be fine. Obviously you'll know if its working if the condensation slowlybegins disappearing.
Edit: I have used this method before and it works, i am not just throwing the idea out there.
Re: Condensation inside JDM front headlight. (Jon D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D »</TD></TR><TR><TD CLASS="quote">A heat gun is a temporary fix, but you'll need to reseal it to fix the problem permanently. Use caution when using a heat gun not to melt the lens. Make sure you give the lens a break not to get too hot and you should be fine. Obviously you'll know if its working if the condensation slowlybegins disappearing.
a blowdryer works pretty well also, cause it doesn't get too hot but hot enough to evaporate the condensation
1 Post
Re: Condensation inside JDM front headlight. (dumafit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumafit »</TD></TR><TR><TD CLASS="quote">
a blowdryer works pretty well also, cause it doesn't get too hot but hot enough to evaporate the condensation</TD></TR></TABLE>
I have never used a hairdryer, but would imagine it takes significantly longer to do this way. Let us know though as i imagine you will probably try the hairdryer first if you don't already have a heatgun.
accord, condensation, fix, front, getcondensation, gun, hea, headlight, headlights, heat, honda, inside, jdm, permanently, pilot, water
