"BRAKE" light is on
"BRAKE" light is on
So today in Northern VA, it got to a high of 20 degrees F. I left work and my "BRAKE" light did not go out. Parking brake was fully released. The light would turn off and on as I was braking. The pedal was nice and firm. So I had been having this situation every winter, and a few months ago, I replaced the styrofoam float that lets the level sensor if the fluid is low. As sure enough as the engine warmed up the "BRAKE" light stayed off, but when I got home I checked the level anyway, and it seemed a bit low. I added more fluid. So I will keep an eye on the level, but I have a feeling my brake master cyl. may need replacing. Is it possible for it to leak within the booster? I took a quick glance and did not see any drips or signs of leaks around the MC or underneath where fluid may drip onto and collect.
Any suggestions as to what to look out for? Is it probably the MC? My R is 18 years old this year and has ~246K on it. This is the original MC still. If it is the MC, should I replace the whole thing or can I just replace a seal?
Thanks in advance!
Thanks in advance!
Re: "BRAKE" light is on
IIRC, the MC and Booster can leak into the interior by the pedals. Have you checked that area? Or any leaks at the bleed screws or corrosion at the hard lines?
Does the light only come on after youve used the parking brake?
Heres some MC and Booster checks:
Thanks in advance!
Thanks in advance!
I shoot brides
My '00 CRV used to do the same thing only on cold days.
y shi - who just learned to ignore it since nothing else was wrong w/the brake system
My memory isn't what it used to be, but wasn't there a FAQ on this many years ago regarding a sticking/failing parking brake light switch!?..
I changed the float b/c some said its possibly saturated and will stick, giving a false low brake fluid reading. After I changed it this past October, I havent had this issue pop up until last night. This "BRAKE" light staying on issue until engine is warmed up has been going on for years, but the only new variable is the actual low fluid. My fluid is kinda dirty, it has the greenish-brown filth floating around in the reservoir, some gets caught in the plastic filter/screen. I don't think that stuff will ever get fully flushed out and will never stop showing up.
Thanks for taking the time to post up those pics of the service manual! much appreciated!
I will look into that, thanks!
My 01 CRV did this on the really cold days once or twice last year. Changed the nasty fluid when I did a brake job which seemed to help.
It got down to 17 degrees here this morning - had the brake light on for about half of my 25 mile ride to work. Parking brake wasn't sticking, fully released.
No leaks anywhere that I could see.
Same my 2000 LS had the Brake light on too when its cold. It goes off after the engine warms up. Also top off the fluid too. I did that and it did helped.
You need to go under and look where your pedals are. Look at the brake pedal switch where it touches the brake pedal itself. There may be a missing rubber plug. The rubber plug engages with the switch to turn off your brake lights.
Hes not talking about the brake lights (tail lights). Hes talking about the "BRAKE" indicator on the gauge cluster, ie when the E-brake is engaged.
To the OP, I know what the problem is and its a very simple fix. Honda had a service bulletin years back to fix this issue as it happens to all integras with high mileage during cold weather.
You can either pop off the master cylinder cap and clean the float and the cap assembly, which will be filled with dirt and grit most likely, or just purchase a new cap and float assembly from Honda, it was only 14$ cdn.
I ended up cleaning mine up while waiting for the new float assembly and my cluster brake light never ever came back on again during cold startups. I never even bothered putting in the new assembly I'm just holding onto in case I need it in the future.
I took the whole cap/float assembly out and washed everything up nice in a container with a small amount of dish soap, dried it and re installed and I've never had an issue since.
I'm almost 100% certain this will work for you, it's a pretty common well known issue for the old timers such as myself lol. Best of luck I hope this fixes your issue.
I'm thinking that the circuit completes through the emergency brake handle switch and the float-level in the Master Cylinder. I suspect that the float-level is the culprit like B16EJ said.
But either way I'm keeping an eye on it, b/c the fluid was pretty low. If it gets low again, I'm going just to replace brake master cylinder, which all data seems to be point in that direction since I can't see any leaks at any of the calipers or in the engine bay under the brake master cylinder.
Thanks!
#1 Super Guy
Fluid gets low because....
A - There is a leak
B - Your pads have worn down
For the leak, don't just start replacing things cause it probably wont solve your problem. Get under the car and look for fluid. Check the backside of your calipers (where the piston is). Check both ends of all your brake hoses. Check the ABS unit. Check the connecting joint on the firewall. Get in the foot-well and look for fluid by the brake pedal pushrod. Fluid will not leak into the booster and magically disappear. It's nasty stuff and you will find it if it's leaking.
For worn pads, topping off the reservior will fix the light. If it comes back on again soon after, it's most likely a leak.
If you don't have a leak, and you've topped off the master, and you've cleaned/replaced the float, then...... Check the parking brake handle switch. It's underneath the e-brake console cover (or armrest). It's just a crappy dip switch that grounds out to the chassis when the e-brake is lifted. If yours is sticky, it may not be popping out when you put the handle down. Then as the chassis heats up from the exhaust pipe, it might start completing the circuit which will cause the light to come on.
A - There is a leak
A - There is a leak
A - There is a leak
-Unfortunately sometimes people also confuse this issue with a faulty/worn master and replace the master for nothing.
So OP first thing I would do in such a situation before spending money on parts, if you haven't found any leaks, would be to clean the cap, float and filter and reservoir toroughly first and bleed the whole system because your brake oil seems like past due to start with and that may very well be at the root of the issue you are experiencing.
My guess is that with fresh brake oil, you won't see the level going down or the brake light coming on about until next time it's due for servicing again.
As you probably know, humidity builds up in the system over time and in the long run it becomes trapped inside with brake fluid which give you somewhat of a false reading if you consider only fluid level, when brake oil is really old. Plus as your oil degrades, it's boiling point/resistance to heat goes down and a small part of it evaporates along with it's constantly growing water content as it slowly loses it's proprieties...which might get that light on or trick you into thinking that there is a leak in your system when in fact, there isn't. In my experience, topping off the oil usually works for a while and will only be a temporary solution until enough contaminated fluid evaporates again due to heat or until you bleed your brakes as far as the light is concerned, especially if you don't track your car.
If you track your car hard or go for a full track day in pretty hot conditions or where the car rests for less than an hour between sessions for instance, it might have lost a bit of brake fluid by the end of the day and that's normal.
If you occasionally track your car or just do one or 2 short sessions and you get the light or find yourself having to top off the oil after just a few sessions to get that brake light off, you might want to replace the fluid and bleed the whole system if the light comes on, even if the fluid still looks good to the naked eye or hasen't been in for a long time.
Thanks for the suggestion SR! I wish I felt comfortable doing a brake fluid flush myself, bc I would completely flush all the lines till I didn't see any more filth floating around in the brake MC reservoir. I had it flushed about 1.5 years ago, and only have driven about 10k since then, but when my buddy did the flush he didn't flush it well enough to the point where my OCD wasnt' bothered by it, lol.
I don't track the car in any way, its has been and always will be my daily driver.
I'm going to really have to consider some of the offers Ive been getting for my R, she deserves better than what I can do for her now.
A - There is a leak
A - There is a leak
I have had worn pads before on this car, but never did the light ever come on due to low level brake fluid. Good to know, thanks.
JSPECHB
05-25-2004 04:25 PM
