towing hook + garage jack = ?
Old 09-10-2004, 08:09 AM
Pompiuses's Avatar
Default towing hook + garage jack = ?
I just bought a small garage jack. Nice to have when doing oil change and other minor things.
Only problem is my car is lowered a bit so the jack doesn't reach all the way under the car. Only solid point I'm able to reach seems to be the towing hook. Is it safe to use the towing hook to jack the car up? Will I damage anything by doing so?
Old 09-10-2004, 08:18 AM
Mugen Type R's Avatar
i do it all the time but it doesnt get my car high enuff to take off my wheels with a regular jack
Old 09-10-2004, 09:01 AM
cjames235's Avatar
Default Re: (Type R 98-870)
yea you can use that but i use the little bump that is right in the middle of the underside of the radiator support, straight infront of the header......... and yea like the post above unless you have a bigger jack it probly wont get the wheels off the ground but it will get it high enough to crawl underneath and change the oil
Old 09-10-2004, 09:21 AM
tnord's Avatar
Default Re: (cjames235)
don't be crawling under cars without jackstands.
<---has had a car fall off of a jack.
Old 09-10-2004, 09:35 AM
Ill
Ill's Avatar
Default Re: towing hook + garage jack = ? (Pompiuses)
Jacking up the rear of the car from towing hook is normal. From the front, I don't like the idea of using the tow hooks, because this jacks up the car from off center, placing a large twisting load on the core support and the frame.
I put some 2x6's (you can use 2x4's too) lengthwise in front of my front tires, then drive up onto them. This gives me the extra bit of room to get the floor jack under the center jack point in the front (that little metal bump sticking down, that the front plastic splash pan is molded to go around).
Ditto - Use jackstands. Jack alone is not safe when under the car.
Old 09-10-2004, 10:14 AM
Taristin's Avatar
Why not just make a sequence of stair steps with 2x6's or some other wood, and drive it up so it's high enough to get a jack under it?
Old 09-10-2004, 11:22 AM
Pompiuses's Avatar
Default Re: towing hook + garage jack = ? (Ill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ill &raquo;</TD></TR><TR><TD CLASS="quote">
Great ide! Why didn't I think of that
And, of course, I never lie under the car without jackstands.
Old 09-10-2004, 11:28 AM
Bradstard's Avatar
Or if you want the extra bling....
http://www.jhpusa.com/catalog/...d=733
Old 09-10-2004, 11:34 AM
Mugen Mike's Avatar
Default Re: towing hook + garage jack = ? (Fat Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">Or if you want the extra bling....
You can get them cheaper at: http://www.calcarcover.com/pro...&s=on
Old 09-10-2004, 11:39 AM
KOALA YUMMIES's Avatar
Default Re: towing hook + garage jack = ? (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">
Or you can get them even cheaper at Home Depot out of 2x4s
Old 09-10-2004, 11:44 AM
bender's Avatar
I don't think you'll hurt anything by jacking there. It seem sto be standard autox practice when changing wheels: jack up the back end using the rear tow hook, and jack up the front using the little bump in the middle.
I <U>think</U> (correct me somebody) the Helms manual even calls those out as jacking points.
Old 09-10-2004, 12:04 PM
Mugen Mike's Avatar
Default Re: towing hook + garage jack = ? (bender)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bender &raquo;</TD></TR><TR><TD CLASS="quote">I don't think you'll hurt anything by jacking there. It seem sto be standard autox practice when changing wheels: jack up the back end using the rear tow hook, and jack up the front using the little bump in the middle.
I <U>think</U> (correct me somebody) the Helms manual even calls those out as jacking points.</TD></TR></TABLE>
The REAR tow hook is a jacking point, but he's talking about the FRONT tow hook
Old 09-10-2004, 12:05 PM
Collector-o-Guns and Drinker
Splat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bender &raquo;</TD></TR><TR><TD CLASS="quote">I <U>think</U> (correct me somebody) the Helms manual even calls those out as jacking points.</TD></TR></TABLE>
I believe you are correct in those being the preferred jacking points - tow loop on the rear, bump on the front.
Old 09-10-2004, 01:19 PM
PatrickGSR94's Avatar
Default Re: towing hook + garage jack = ? (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">
the cheapest - FREE! I made these out of plywood leftover from the work bench I designed and my dad and I built in the 3rd garage space.
Old 09-10-2004, 01:38 PM
DC2fanboy's Avatar
The REAR tow hook is a jacking point, but he's talking about the FRONT tow hook </TD></TR></TABLE>
When he said tow hook I was just thinking of the helm's specified rear tow hook too and wondered how he was going to change the oil jacking it up from the back... LOL
The other alternative is to get this bling bling aluminum jack... and it's light enough to take to the track to show off the "one-pump-to-chassis" too
Incidentally, it's on sale for $179.99 now... WTF I swear I paid $249.99 back in the day...
To think, I used to jack it up with an OEM GM scissors jack (because it has the iron attached to the crank) and then with a big jack... wooden planks work well too...
Modified by DC2fanboy at 5:48 PM 9/10/2004
Old 09-10-2004, 01:46 PM
.water's Avatar
Default Re: towing hook + garage jack = ? (DC2fanboy)
how heavy is that car jack?? i got from Coastco...like under 100 and 3ton jack..its for lower car..like 1 finter height...but problem is heavy...i live in APT...hard to bring up and down..haha
Old 09-10-2004, 01:53 PM
DC2fanboy's Avatar
Default Re: towing hook + garage jack = ? (SpoonTypeOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonTypeOne &raquo;</TD></TR><TR><TD CLASS="quote">how heavy is that car jack?? i got from Coastco...like under 100 and 3ton jack..its for lower car..like 1 finter height...but problem is heavy...i live in APT...hard to bring up and down..haha</TD></TR></TABLE>
This one is around 40-45lbs I'd say... I did look at the costco one before getting this one... I was kind of iffy on build quality, especially the release valve, it felt like the Harborfreight one, but was 3 ton instead of 1.25 ton... but it was a good deal though, if I remember correctly, the costco one comes with 2 stands, 2 chocks and knee pads or something... was almost too good to be true, so I just went to sears for the piece of mind... Plus, if it breaks, I can go back to Sears, no questions asked...
Old 09-10-2004, 02:41 PM
bender's Avatar
I've got the Harbour Freight one; low enough to get under my car, 6 pumps and I've got 2 wheels off the ground. 35 lbs, easy to take to the track. I've had mine over a year with no problems. I probably see 30 of them at every autox and I've never heard of anyone having a problem.
I think this is it here: http://www.harborfreight.com/c...91039
but WTF! $79.99?!? I almost felt guilty when I only paid $139.00!
Old 09-10-2004, 02:49 PM
bender's Avatar
Yes, yes, thanks. I guess I have to read every little word
Helms manual does say rear tow hook and front "jack lift platform" in the center.
I wouldn't feel good at all using the front tow hooks...
Old 09-10-2004, 03:36 PM
DsITR's Avatar
Otay..
here are the acceptable "jack points" according to Manuel Helms
I don't think I've ever used this one
...says nothing about the front tow hooks.. I have actually seen the front tow hooks, bend in while jacking not a good idea IMO.
I have the harbor freight jack as well.. Thing has seen double duty jacking up my ITR and Lude @each event for ~1yr.. no problemo so far
To change my oil, I jack up from the drivers side jacking point (underneath the door) put a jackstand under where the LCA connects to the chassis. Then do the same to the passenger side..
Old 09-11-2004, 03:38 AM
Nvious R's Avatar
Location: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: towing hook + garage jack = ? (DsR)
i use the one in the front and it works just fine for me but i do have some precautionary measures. I take the wheel off driver side and slap it under the car's side jack point while the car's jacked up. Acts like jackstand even thought it doesn't hold the car up, if anything were to happen, it would land on the tire.
b16egsi
10-27-2003 11:45 AM
dclub01
08-18-2003 04:21 AM
Seann
10-24-2001 02:22 PM
Darren94ls
07-13-2001 03:05 AM
Quick Reply: towing hook + garage jack = ?
