Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Acura Integra Type-R (https://honda-tech.com/forums/acura-integra-type-r-8/)
-   -   Battery options?? (https://honda-tech.com/forums/acura-integra-type-r-8/battery-options-809832/)
jdmspoonitr Mar 24, 2004 12:19 AM
Battery options??
What have you guys tried?
I'd prefer it to be lighter than the stock one and fit in the stock location. Let me know what you guys are using because my damn battery dies on me every other day.
I need something that has good life too. I'd sacrifice better life for the weight. Just need something hassle free. Budget = 100 bucks.
Thanks in Advance https://honda-tech.com/forums/images...es/emsmile.gif
00 FBP ItR Mar 24, 2004 01:39 AM
Re: Battery options?? (jdmspoonitr)
Pmed you.
My sig.
Art Vandeleigh Mar 24, 2004 01:43 AM
ken, i just covered this the other day in my ase courses. if your batt is dying on you every other day...you might have a problem with your charging system, ie alternator.
1) what is the voltage of your batt when the engine is off?
should be around 12.6 or higher
2) what is the batt voltage when you are trying to crank the car?
should not drop by more then 2 volts or so...
3) what is the output voltage of the alernator when idiling and when rev to about 2k or so rpm?
should be around 13.5 to 15 volts give or take some when your rpm is around 2k...if it is not within this range then you probably have a problem with your charging system.
for a 4 cyl engine...the starter should use about 150 or so amps...they say the batt should be double the starter draw....now this is a situation where weight is of no concern and you just want the batt to start the car and work. but i think the batt must be able to handle at least 200 amps to give you a reliable no hassel start every time.
consumer reports gave the kirkland brand batt from costco very high ratings!! i use that in my accord with a 400 CCA rating. that is more then enough juice to start the car and run any electrical system while the car is ideling. i think i paid $40 or $50 for the batt a few months ago, but with the increased CCA, the batt is larger and heavier due to the increase in size and quantity of the lead plates inside the batt...
jdmspoonitr Mar 24, 2004 11:59 AM
Re: Battery options?? (Art Vandeleigh)
Thanks for the input! https://honda-tech.com/forums/images...es/emsmile.gif
I don't think it is my alternator as of now. I didn't drive my car for 6 months a while back and I left the battery hooked up https://honda-tech.com/forums/images...s/emhammer.gif on me.
So it drained completely and sat. I think that the battery just can't hold a charge anymore. If I get a new battery and it still acts up then I'll look at the alternator next.
[HrZn]4life Mar 24, 2004 01:24 PM
not considering an Optima?
Misfit Mar 24, 2004 01:33 PM
Re: Battery options?? ([HrZn]4life)
I just went to sears and picked up a diehard battery for 60 bucks with old battery turn in.
B2FiNiTY Mar 24, 2004 03:09 PM
Heeltoe NRG Battery https://honda-tech.com/forums/images/smilies/emthup.gif
mugenracer Mar 24, 2004 04:50 PM
Bosch OE fitment!
onyx00 Mar 24, 2004 06:15 PM
Re: (mugenracer)
I went to Autozone and got the basic, el cheapo battery. It's a f*king battery guys, gimme a break.
Dr Pooface Mar 24, 2004 06:38 PM
Re: (onyx00)
I have a Hawker 11 lb deep cycle battery, I think you can get them for around $20.
ITR#132 Mar 24, 2004 08:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">
Interstate-Direct Replacement
Approx. same weight as stock, Fits in stock location, Better than stock Panasonic, Very Good life, Hassle Free, Under 100 bucks.
NAR Cd7 Lude Mar 24, 2004 09:37 PM
Re: Battery options?? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Heeltoe NRG Battery https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
Why not NAR-SPEC Dennis? Same stuff, lower price! https://honda-tech.com/forums/images/smilies/emthup.gif
Jowee Mar 24, 2004 10:34 PM
Re: (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">I have a Hawker 11 lb deep cycle battery, I think you can get them for around $20.</TD></TR></TABLE>
Where did you get yours from? I'll rather search around town and get one for $20 instead of making people rich and paying $100.
DsITR Mar 24, 2004 10:48 PM
My battery
https://honda-tech.com/zerothread?id=734430
oz#227 Mar 25, 2004 12:37 AM
Re: Battery options?? (DsR)
Here's mine, with Custom Battery Holder.
http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg
Yeah, it's an Oddessey, Here's another shot.http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg
Later.
Philly_NBP_R Mar 25, 2004 04:35 AM
Re: Battery options?? (oz#227)
https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
good thread
Nick
(who needs to get a new battery soon to replace the tired oem one...)
Dr Pooface Mar 25, 2004 05:24 AM
Re: (ITR 98 1162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 &raquo;</TD></TR><TR><TD CLASS="quote">
Where did you get yours from? I'll rather search around town and get one for $20 instead of making people rich and paying $100.</TD></TR></TABLE>
It was an old group buy here a year ago, but I remember that they were available at that price anytime.
Edit: Found it. Price has gone up quite a bit, but they're still a cheaper option. It's the G13EP located in about the middle of the page: http://www.surplusev.com/
I bought it without the automotive terminals and then fabbed my own for cheap. It's made by Hawker, just doesn't say so anywhere. Had mine for a year now no problems.
Bradstard Mar 25, 2004 05:33 AM
I'm running a yellow top optima. I am very pleased with it so far. https://honda-tech.com/forums/images/smilies/emthup.gif
The price is not good though..... https://honda-tech.com/forums/images...s/emthdown.gif
jdmspoonitr Mar 25, 2004 12:38 PM
Re: Battery options?? (Fat Bradstard)
I hear that yellow top optima does not fit in stock location is this true?
Kicker773 Mar 25, 2004 12:40 PM
that looks really nice? wanna sell me one https://honda-tech.com/forums/images...es/emsmile.gif it is smaller and can maybe give a lil room for other things in the engine bay.. give us some info on how you got all these nice goodies.. https://honda-tech.com/forums/images/smilies/emwink.gif
Rhetoric Mar 25, 2004 12:59 PM
Re: (Dr Pooface)
I bought it without the automotive terminals and then fabbed my own for cheap. It's made by Hawker, just doesn't say so anywhere. Had mine for a year now no problems.</TD></TR></TABLE>
I got my G13EP from Surplusev.com as well. No problems to date, I've been using it for about 8 months now?
Art Vandeleigh Mar 25, 2004 02:00 PM
Re: (Rhetoric)
The price and weight are a GREAT selling point...but you have to understand some things about deep cycle batteries. the deep cycle batt supplies an almost constant usually relatively small amount of amperage. while a car would need a large amount of amps during cranking, but much less to almost none when the car is running.
when you have a deep cycle, the batt continues to put out to the point of it beiong almost dead and then it recharges. inside the plates of deep cycle batts, a thicker layer of paste allow the batt to withstand hundreds of these repeated almost full discharge and recharge cycles. but this then leads to less surface area of the lead plates, thus leading to less power and longevity issues.
has anyone owned a deep cycle batt on a daily driver for longer then, say 2 or 3 years?
[HrZn]4life Mar 25, 2004 02:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">I hear that yellow top optima does not fit in stock location is this true?</TD></TR></TABLE>
Optima started making a size that will fit integras; just picked one up couple weeks ago.
HiRevn Mar 25, 2004 07:24 PM
I slapped a Wally mart battery in my car. It has more CA's and CCA's than the DieHard I replaced. On top of that, it was $20 less and had 6 months more warranty than the DieHard.
AzN_Flava Mar 26, 2004 12:10 AM
Re: Battery options?? (HiRevn)
i bought a hawker gp13 the 11 pound battery, and I've had a few problems.
I'm not sure if it is the batteries fault, but basically, if i stall, or if i shut off my car after my car has been warmed up and turn it on right away, my car seems to not have enuf juice to start. It always needs to be jumped to start.
I mean it is super light, and cheap but the fact that if i stall and wont be able to start up right away is kinda scary.
Any suggestions on if it is the batteries fault or soemthign else?
