Wont go over 6300 rpm. 96 GS-R Teg.
Hey guys this problem just started yesterday.. I was getting on the on ramp to get onthe freeway.. N it was empty so i decided to gun it .. Once the rpms Reached about 6300.. The car sounded like it was stuck .. I have a video ill post up in a bit.. Any thoughts..
Re: Wont go over 6300 rpm. 96 GS-R Teg.
post video .
Originally Posted by Null3D
(Post 47618058)
post video .
http://youtu.be/N5MGu3j-Mq4?hd=1 |
whats your check engine light ?
I honestly dont know why the CHECK ENGINE light is on.. I have to check that. BUt all i know is that its has a V2 AEM INTAKE . And the CLutch Relase bearing needs to be changed. But i think im just going to switch the clutch to stage 1.
Pull that CEL code, that is likely going to tell you what is happening.
ok...
I believe VTEC wont engage when you have a CEL. Pull the CEL, fix the problem, and you should have no problems afterwards.
Originally Posted by CompanyFlow
(Post 47621360)
Check your oil level and pull the cel to see what other problems you are having that could be related to it cutting off. |
IM checking with my uncle who is a mechanic he has the machine to check the CEL Codes.. And i just noticed it is leaking oil from the top .. and The oil is burning .. i just checked it..
your oil might be low
Originally Posted by John M
(Post 47624022)
Mine was doing exact same thing. It was a bad cluster.
Originally Posted by Solidis
(Post 47624255)
Yea.. it is.. FML..
(Post 47625258)
then add oil. the motor wint rev high cause vtec is based on oil pressure and when your oil is low it wont enguage which is putting your car in limp mode. your lucky you havnt spun a rod bearing yet. does the engine seem to be knocking? make a vid of the engine running in the engine bay and rev it up a tad.
OK AND ABOUT THE CHECK ENGINE LIGHT.. THIS IS WHAT CAME UP -
CODE P1382 -Cylinder Position Sensor No Signal & :cry: CODE P1259 -VTEC System Malfunction.. BUT VTEC KICK-IN ??? (PLUS FOUND OUT I HAVE A BROKEN HEAD GASKET THATS WHY THE OIL LEAKS) ANY GOOD SUGGESTIONS ON A GOOD BRAND TO BUY FOR HEADGASKET. |
How did you conclude the head gasket blew?
Oem is always best |
any head gasket will do. unless you are boosting.
(Post 47627123)
Low oil pressure won't cause this...low oil pressure won't allow vtec to engage..not stop it at 6500 rpm.....but first check the codes.it canbe a million things....that cel will tell u a lot...Are u losing antifreeze also.?alot of Honda motors seep oil through the head gasket..doesn't mean it's blown.......I like to halomar the gasket.its like a copper spray?.cl position code.. Sounds like bad ckps ....I believe that is build into the module in distributor...your ckps code is probably intermittent
From what i know when i bought the car the last owner said he replaced a Cylinder .. it was bad.. from the obd machine. it did say cylinder mis-fire.. but after the reset was done it was gone just the last two codes i posted.. the reason that i say the gasket . is because my uncle is a professional mechanic.. and he told me its only leaking on one side.. but idk.. The images i uploaded are from were i can see were the oil is..
http://i1163.photobucket.com/albums/...8_152041-1.jpg http://i1163.photobucket.com/albums/...718_152020.jpg |
Luckly im selling my 95 civic.. so i can bring this teg back to life.. Hopefully with some extra goodies
(Post 47625258)
http://youtu.be/Bs4SabC-yXc |
Motor sounds healthy. Oil is coming from the valve cover gasket in the pic. most times it is not the head gasket that is leaking. It is usually the VTEC solenoid gaskets, cam seal, distributor oring, or a combination of the three. To me though, that is the valve cover gasket leaking. Have you checked to see if there is water in the spark plug chases. Are you sure its not crank position sensor? If it is calendar position sensor it is time for a new distributor from what I have read.
Yeah i sent him a massive pm on how to replace the gaskets mentioned haha. I want him to first add oil to proper mark on the dipstick and then reset the ecu and hook it back up and go drive the car and see if it revs past 6300. Now if that doesnt work i would try a known good b series dizzy and that should do the trick. Keep me updated bro i work at honda and can get you employee discount.
