95 gsr brake problem please give input
Old 05-30-2011, 09:46 PM
oldschoolfever's Avatar
Default 95 gsr brake problem please give input
ok so i have a 95 gsr sedan .disk brakes all the way around ofcourse..drivers side rear was sticking or something the other day so im gonna replace the caliper and shoes and everything...but question i have is ...why would my brakelights no longer work now?...could this problem trigger a fuse to blow or something?..........plus give input and its much appreciated ...thanks!
Old 05-31-2011, 09:06 AM
Daisy... Daisy...
Dogginator's Avatar
Default Re: 95 gsr brake problem please give input
Check the slider pins for free motion on the caliper in question. The brake lights are not related to the calipers. The switch is on the brake pedal.
Old 05-31-2011, 03:06 PM
Mt3c's Avatar
if brake lights are out, check the bulbs first than brake switch. Most likely culprit are the bulbs.
Old 05-31-2011, 04:28 PM
fcm
Old Fart
fcm's Avatar
A blown fuse or bad brake light switch is far more common then all the brake light bulbs going at one time. 94
Old 05-31-2011, 05:05 PM
cr125r's Avatar
check switch under dash off brake lever
Old 05-31-2011, 06:50 PM
Oreo-TeCk's Avatar
if the piston on the caliper goes back easy then most likely the culprit for the brakes sticking is hardware... pull the pins and inspect... you can use some brake and caliper grease on the pics then put it back together and see if the problems goes away... check bulbs first then go from there...
d0ugch0i
02-16-2024 04:44 PM
Lsv4free
07-23-2014 07:05 PM
tjohnson329
02-15-2014 01:51 PM
TomCurllyFry
03-25-2013 09:29 PM
hAtChXcElR8tion
05-17-2004 07:06 PM
Quick Reply: 95 gsr brake problem please give input
