will HX rims fit on a '94 gsr??
Hype-R Stalker
Re: will HX rims fit on a '94 gsr?? (iVteC_PoWeR)
If by hx you mean These ...
Then no, they will Fit the lug pattern, but they hit against the caliper on the face.
Re: (lillaoboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lillaoboi »</TD></TR><TR><TD CLASS="quote">is it me or are those rims pretty ******* sexy?
always wanted to see them on a teg.
if it happens post pics!
Agreed they are.
I'd rock them in a heartbeat
Agreed they are.
Cigarette Squad
Re: (Boostedb20EH2)
goto a local rim store bring one of the hx's to have right spacer and get two spacers and it will clear should only be around 5$ per spacer if not less i only payed 2$ per spacer
Re: (McGeeTM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by McGeeTM »</TD></TR><TR><TD CLASS="quote">goto a local rim store bring one of the hx's to have right spacer and get two spacers and it will clear should only be around 5$ per spacer if not less i only payed 2$ per spacer</TD></TR></TABLE>
Does it make the rims stick out noticeably? I think I'd rather shave the calipers than run a spacer.
1 Post
Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline »</TD></TR><TR><TD CLASS="quote">it will not fit unless you have spacers or grind down the calipers</TD></TR></TABLE>
just was gonna say that! There's been numerous amounts of threads about this.....
Re: (iVteC_PoWeR)
Re: (iVteC_PoWeR)
umm sexy wheels when seen in person
but like said already get some spacers so they will clear. they dont have to be huge spacers, just enough to clear the caliper( 2-3mm) should be fine, buddy of mine ran same rims on gsr and used 2.75 mm spacers and fit fine, also gave him a lil wider wheel base so cant go wrong, if not then shave the caliper. hope this helps. GL
yah, this has been asked to death-- they will fit, but you'll have to shave down the calipers just a tad for the clearance.
Why post if its been asked so much you wonder?
I really wanna see those rims on a teg =D
Re: (youradhere)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youradhere »</TD></TR><TR><TD CLASS="quote">yah, this has been asked to death-- they will fit, but you'll have to shave down the calipers just a tad for the clearance.
I really wanna see those rims on a teg =D</TD></TR></TABLE>
My suggestion is to use heavy duty washers or they will bend...I used two on each stud for clearance...Here are pix of my HX rims on the integra...
if you use a spacer like everyone else says yes but why not get the jdm itr 4 lig? its cheap and better upgrade same looking wheel and a 15' not 14'
Re: (H Twenty Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igone916 »</TD></TR><TR><TD CLASS="quote">
those wheels look clean on an integra. they could easily be mistaken for jdm type-r wheels.
Banned
Re: (H Twenty Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H Twenty Teg »</TD></TR><TR><TD CLASS="quote">Those are waaay too small, and the offset suck ***.</TD></TR></TABLE>
alright baller. post up your integra with the ****** DUBS on it then.
Location: Why To Steal My Car, NC, United States Of America
Re: (steluta)
why in the hell are you posting your stupid cigarette commercials??? mods ban this sucka!!! i pity the foo!!! hahah
