Whats next...?
Well, graduation just came by, and I have alot of money to spend.
I have all the basic bolts-ons either on, or about to go on but paid for Intake Intake manifold/gasket header test pipe exhaust motor mounts ECU clutch/flywheel The only thing I could basically see left to do is tune the whole setup and I have an chipped OBD1 ECU and a VAFC and FPR for that. Are there anymore bolt-ons I could do? If i take off the head, its gonna be the whole deal, valvetrain and bottom end, so that is gonna be alot of dough. Is there any way I could make free up more power? |
Re: Whats next...? (DeeSeeToo)
cams/cam gears>springs/retainers>advance timing
well if you don't have suspension ( and if you do then just ignore this) then i would up the suspension, b/c there is no use in having power if you can't hold it on the road. i would also save some of the money for down the road cause you never know
Re: Whats next...? (ponytd)
up, So basically, it that it for bolt-ons? My suspension is basically set (apexi coilovers)
BTW could anybody post up numbers of b18c1's with maxed out bolt-ons? |
up...no more bolt-ons left?
yes youre done w/ bolt ons. time to step up to the plate. https://honda-tech.com/forums/images/smilies/emwink.gif
Re: Whats next...? (Threatcon13)
If you have thousands on tap, Boost!
Re: Whats next...? (IntEGNYC)
Get some Cams and Cam gears and tune that biatch https://honda-tech.com/forums/images/smilies/emthup.gif
