What would cause my speedometer to melt like this?
Old 12-22-2014, 06:49 PM
  #26
Thats whats in cable speedo hondas. The service manual even states it as the vehicle speed sensor. Its technically made up of the speedo gear on the trans, the cable, and the sensor itself inside the cluster.
m4xwellmurd3r is offline
Old 12-22-2014, 07:39 PM
  #27
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
Default Re: What would cause my speedometer to melt like this?
most of the ones with a cable the speedo is completely mechanical. This is the "sensor" inside of the one on an 86 Accord, the white plastic piece contains a simple reed switch, most early civics are the same setup
this is where the magnet is located, every time it passes the reed switch, a pulse is generated
most of these will have a white box inside of the cluster, this is what is actually inside of most of them lol
some have more circuitry to create a signal like an early VSS, but I wouldn't consider it a true VSS until they went to the standard of the transmission mounted sensor, with a 5 volt square wave output
lostforawhile is offline
meric0786
07-21-2008 08:15 AM
bubbakrip
03-29-2006 09:37 PM
B18C1EF
12
05-31-2005 04:49 PM
turbod16y7vtec
11-19-2004 07:11 PM
kevinm1981
04-20-2004 05:36 PM
Quick Reply: What would cause my speedometer to melt like this?
  • Ask a Question
Question Title:
Description:
