when driving RPM's don't go to idle.
Old 12-18-2004, 05:46 PM
IntegraLs94Cam's Avatar
Default when driving RPM's don't go to idle.
For some reason whenever i drive my car and put it in neutral the RPM's dont go down to 750 like it should .. it stays at 1,300-1,400 RPM it only goes down to 750 RPM when i come to a dead stop, but when im rolling in neutral it stays at 1,300-1,400 RPM... is there something wrong with the car or is it because of cold weather... Even when the car is fully warmed up it still does this ... i just started to noctice it .. it is kinda werid..... is this bad for the motor to do that ? Anyone help plz
Thanks,
Cam
Modified by IntegraLs94Cam at 3:19 PM 12/20/2004
Old 12-18-2004, 06:52 PM
njandrewg's Avatar
Default Re: when driving RPM's don't go to idle. (IntegraLs94Cam)
i think it goes like that cuz of the wheels rotating
Old 12-18-2004, 07:10 PM
I'm here for the gangbang!
Lewie's Avatar
Default Re: when driving RPM's don't go to idle. (njandrewg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">i think it goes like that cuz of the wheels rotating</TD></TR></TABLE>
I'm pretty sure that's correct. At least my car does that.
Old 12-19-2004, 08:39 AM
Default Re: when driving RPM's don't go to idle. (Lewie)
so my car is normal .. hmm i guess i just never nocticed that befor .. thanks guys
Old 12-19-2004, 08:44 AM
hotsuma23's Avatar
wtf are you talking about an auto or manual? I dont know about autos, i never drive them but in my manual teg when ever i put it in neutral going 40 or any speed the rpms drop to 750 ish right whenever i put the clutch in. The drivetrain is seperated from the engine whenever the clutch is disengaged. Therefore, the speed of the wheels wont affect engine idle speed.
Old 12-19-2004, 08:51 AM
tegsallgood's Avatar
Default Re: when driving RPM's don't go to idle. (hotsuma23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotsuma23 &raquo;</TD></TR><TR><TD CLASS="quote"> in my manual teg when ever i put it in neutral going 40 or any speed the rpms drop to 750 ish right whenever i put the clutch in. The drivetrain is seperated from the engine whenever the clutch is disengaged. Therefore, the speed of the wheels wont affect engine idle speed. </TD></TR></TABLE>
exactly. the wheels spinning should have no affect o the motor when the drivetrain is disengaged from it. as long as your clutch pedal is depressed, the trranny and motor are two seperate entities. my car drops to idle and stays rok steady even if i pop it into neutral at 80 and coast to a stop
Old 12-19-2004, 08:54 AM
hotsuma23's Avatar
Default Re: when driving RPM's don't go to idle. (tegsallgood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsallgood &raquo;</TD></TR><TR><TD CLASS="quote">
exactly. the wheels spinning should have no affect o the motor when the drivetrain is disengaged from it. as long as your clutch pedal is depressed, the trranny and motor are two seperate entities. my car drops to idle and stays rok steady even if i pop it into neutral at 80 and coast to a stop</TD></TR></TABLE>
Bingo
Old 12-19-2004, 06:32 PM
96tegsr's Avatar
i notice that too. My cars rmp is about 1100 -1200 rpm when the car is still rolling on neutral, but as soon as i stop, it goes back down to 750 or so..
Old 12-19-2004, 06:48 PM
PLAGUED_DB7's Avatar
Default Re: when driving RPM's don't go to idle. (96tegsr)
Is that a bad thing??
I will be hauling *** then coast downhill @ about 70-80ish and the rpm's stay at about 1100-1300 never higher never lower..... when I stop 750+/-
Old 12-19-2004, 07:41 PM
blk_db2's Avatar
Default Re: when driving RPM's don't go to idle. (PLAGUED_DB7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96tegsr &raquo;</TD></TR><TR><TD CLASS="quote">i notice that too. My cars rmp is about 1100 -1200 rpm when the car is still rolling on neutral, but as soon as i stop, it goes back down to 750 or so..</TD></TR></TABLE>
after letting go of the gas mine will drop down to 1100 rpm right away, but it probably only stays there for about 10sec(if that) I've notice if you continue to coast it will actually goto 750...... this happens after the manifold vacum stabilizes......
or
maybe the IACV is reading the ecu with is reading the pwr steering speed sensor with inturn tells the IACV to open due to the additional load on the engine.....just a theory....
Old 12-19-2004, 07:47 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotsuma23 &raquo;</TD></TR><TR><TD CLASS="quote">wtf are you talking about an auto or manual? I dont know about autos, i never drive them but in my manual teg when ever i put it in neutral going 40 or any speed the rpms drop to 750 ish right whenever i put the clutch in. The drivetrain is seperated from the engine whenever the clutch is disengaged. Therefore, the speed of the wheels wont affect engine idle speed. </TD></TR></TABLE>
maybe someone just wants us to think he has a manual? mine never goes to idle...always stays up a bit... maybe ur car is like, dont u ******* dare put me in first...i better rev a bit...haha
Old 12-19-2004, 08:47 PM
gsrlkn412s's Avatar
no big deal. quit freaking out about it. just drive.
Old 12-19-2004, 09:02 PM
631 Teggy's Avatar
Default Re: when driving RPM's don't go to idle. (gsrlkn412s)
My car has been doing this as well ever since I got a chipped p28. Most of you guys are idiots and don't know ****, so don't respond, but here are the symptoms... IntegraLs94Cam let me know if this is a simillar problem...
Driving in gear (manuel), coming up to stop sign so you kick in the clutch and break. The engine revs to 1500 rpms. (actually revving not just SLOWLY falling), and the engine stays perfectly at 1500rpms untill you come to a complete stop. So even at 1mph the motor revs to 1500rpm... It feels like the iac goin crazy, cuz the TB is NOT getting stuck. Obviously it has something to do with the ecu. What we are asking for is a resolution...
TYIA
EDIT: What we are talking about is not NORMAL for our cars. So don't say "my car holds idle at 1000rpm till dead stop" obviously most cars don't drop all the way. This is 1500rpms, you can hear the engine revving. It's not normal, it's annoying. Sometimes the car stalls itself out too... No cel's...
Old 12-19-2004, 11:47 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrlkn412s &raquo;</TD></TR><TR><TD CLASS="quote">no big deal. quit freaking out about it. just drive. </TD></TR></TABLE>
what is a loser!
Old 12-20-2004, 05:18 AM
HONDA RR's Avatar
I have a 99 gsr and it does the same thing but when i removed the power steering belt and drove the car it stopped doing that. I think its the power steering that causes that because its used the engine power to work.
Old 12-20-2004, 10:06 AM
631 Teggy's Avatar
Default Re: when driving RPM's don't go to idle. (MITSUBA)
^^Interesting... I wonder, if it was the power steering. Why did it only start occuring recently? I've owned the car for 3 years, and it's been only doing it for a month now.
Old 12-20-2004, 12:18 PM
..... why would i put it in neutral if i had a auto??? i got a manual ....
I think it is cuz of cold weather .... never noticed this befor till now ... i just wanted to know if it was hurting anything .. i dont think it is but not sure...
Old 12-24-2004, 08:08 PM
bump&gt;..
Old 12-25-2004, 02:02 AM
TrueUntilDeath.com's Avatar
could it be early symptoms of a bad clutch? like when you release the pedal, the clutch doesnt disengage?
when i go into N going about 50+ it drops to about 1k rpm. and then to 500-750 @ idle.
Old 12-25-2004, 12:05 PM
Default Re: when driving RPM's don't go to idle. (FrostWhiteDC4)
update- up top i said that my rpms drop to 750 at all times even when cruising at 80... well this isnt so anymore. just finished my lsvtec a couple of days ago and now it drops to about 1000 when driving, then when stopped drops to the 750 idle... but this doesnt always happen (i think) i dont know what it is. im sure its nothing bad. and no my clutch is absolutely fine.
adseguy's Avatar
OMG I can't believe that I'm the first guy to say this. In Uberdata/Hondata/and AEM EMS there is an option to change your idle revs.
It goes like this:
cold rpm _____
warm rpm _____
moving rpm _____
you can adjust this. In stock form the moving idle is higher the the warm idle! so yes it's normal to have a faster idle while moving!
Old 12-25-2004, 12:13 PM
1Quikgsr's Avatar
Default Re: when driving RPM's don't go to idle. (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">OMG I can't believe that I'm the first guy to say this. In Uberdata/Hondata/and AEM EMS there is an option to change your idle revs.
It goes like this:
cold rpm _____
warm rpm _____
moving rpm _____
you can adjust this. In stock form the moving idle is higher the the warm idle! so yes it's normal to have a faster idle while moving!</TD></TR></TABLE>
Old 12-25-2004, 02:50 PM
Default Re: when driving RPM's don't go to idle. (1Quikgsr)
ok so it is normal to got to like 1300 RPM when driving ??? it only goes to 750 RPM when i come to a dead stop....
My brother cars does not do that .... got me worried .... hmmm it wont hurt anything idleing at 1300 rpm will it?
Old 12-25-2004, 03:03 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam &raquo;</TD></TR><TR><TD CLASS="quote">ok so it is normal to got to like 1300 RPM when driving ??? it only goes to 750 RPM when i come to a dead stop....
My brother cars does not do that .... got me worried .... hmmm it wont hurt anything idleing at 1300 rpm will it?</TD></TR></TABLE>
No it's fine. the default ECU is 750 at a stop and 900 when moving, yet most people see around 1,100 to 1,300 when moving for some reason which is still totally normal.
iCollectStraws
04-23-2008 11:14 AM
LudeNEzz
07-05-2007 09:26 AM
1sikhatch
11-30-2006 09:55 AM
93JDMB18C
11-02-2006 02:03 PM
crx00
03-13-2004 06:39 AM
Quick Reply: when driving RPM's don't go to idle.
