Weird oil leak- 1996 DB8
Old 12-08-2010, 05:42 AM
  #26
EHondaJDM's Avatar
Default Re: Weird oil leak- 1996 DB8
Originally Posted by PatrickGSR94 View Post
295K on original head gasket.
Please hold while I pick my jaw up off the floor
EHondaJDM is offline
Old 12-08-2010, 05:57 AM
  #27
PatrickGSR94's Avatar
All original engine and transmission internals. No big deal really, just gotta take care of it. And yes I still wind it out to redline every now and then.
PatrickGSR94 is online now
Old 12-08-2010, 06:01 AM
  #28
fv8s's Avatar
I have around 200k miles on the OG gasket and that is where mine is leaking
fv8s is offline
Old 12-08-2010, 06:03 AM
  #29
original head gasket? Are you SURE it's the HG leaking? Most often it's something up above that area that's leaking.
Old 12-08-2010, 06:59 AM
  #30
EHondaJDM's Avatar
Well yes assuming you don't just use it as a putt putt mobile.
Old 12-08-2010, 07:23 AM
  #31
fv8s's Avatar
It is the head gasket. All the upper gaskets are new and there are no wet spots. I don't want to hijack the OP's thread, so enough about my motor. I was just trying to help him out. It is a common problem on a high mileage motor. I will post a picture of mine if that helps the OP to prove mine is coming from the same spot and mine is the headgasket.
fv8s is offline
Old 12-08-2010, 02:28 PM
  #32
efvader's Avatar
i saw oil in that area of my old gsr that was an oem rebuild with new bottom end etc and thought headgasket too.
ended up being the spool valve filter/gasket of course. that and the cam plug are the common suspects.
efvader is offline
Old 12-08-2010, 04:39 PM
  #33
I didn't mention earlier that when I had the oil in the same place, I replaced the main VTEC solenoid gasket, dist. o-ring, and cam end plug at the same time, but that didn't fix the leak. Then I replaced the other, smaller VTEC solenoid gasket and that seemed to fix it. #12 is what most people replace, but #14 is what fixed my leak.
Old 12-08-2010, 07:45 PM
  #34
sik96teg's Avatar
i had oil in the same spot it was my vtec solenoid and my distributor O ring. In my case i replaced my head gasket just to find that out. Also looking at your second pick it looks like its the vtec solenoid gasket that mates to the head.
sik96teg is offline
Old 12-08-2010, 09:00 PM
  #35
No-Traction = Fun
CaliforniaDad's Avatar
Yeah I guess I'll just replace all of those gaskets again. And see if that kills it. Should i use honda bond on them?
CaliforniaDad is offline
Old 12-08-2010, 09:26 PM
  #36
i wouldn't. usually these rubber gaskets become hardened over time. that's what causes them to leak. just be sure all surfaces are clean.. and o ring is lubed, of course
el crapitan is offline
Old 03-22-2013, 05:36 PM
  #37
Okay will do. also dumb question. What is this oil plug here for?
according to this picture... can any1 please tell me the oil pressure specs under vtec at this bolt??? i hooked up a oil pressure gauge and got 25psi when vtec engaged, but cant hear/feel cross over. is this result not enough oil pressure to push the pins and lock the rocker arms?? if not.. what can be causing it to be so low??? please help :/ i cant realy start a new post on this cus im still kinda a new member
Supavillin is offline
Old 03-22-2013, 10:10 PM
  #38
Blackhalo6's Avatar
That port can quickly be used to check the solinoid operation and health. When vtec is engaged, pressure there should be same as or close to oil press at the stock sensor location. Somewhre between 50 and 80. Depends on the age of the filter and pump. Its possible that the small filter is clogged or the solinoid isn't operating correctly. Pull it off and check the filter and you can put 12 volts to the solinoid and watch it operate.
Blackhalo6 is offline
Volksdragn
04-14-2014 06:36 PM
98GreenTegGSR
12-18-2006 11:56 PM
macrohard
08-11-2006 05:15 AM
808State
04-09-2004 06:59 PM
2k2silvertype-s
12-20-2002 07:04 AM
Quick Reply: Weird oil leak- 1996 DB8
  • Ask a Question
Question Title:
Description:
