Re: Weird oil leak- 1996 DB8
Originally Posted by PatrickGSR94
(Post 44177648)
295K on original head gasket. :)
Originally Posted by EHondaJDM
(Post 44177731)
Please hold while I pick my jaw up off the floor
I have around 200k miles on the OG gasket and that is where mine is leaking
Originally Posted by fv8s
(Post 44177813)
(Post 44177791)
All original engine and transmission internals. No big deal really, just gotta take care of it. And yes I still wind it out to redline every now and then. :thumbup:
(Post 44177822)
original head gasket? Are you SURE it's the HG leaking? Most often it's something up above that area that's leaking.
i saw oil in that area of my old gsr that was an oem rebuild with new bottom end etc and thought headgasket too.
ended up being the spool valve filter/gasket of course. that and the cam plug are the common suspects. |
I didn't mention earlier that when I had the oil in the same place, I replaced the main VTEC solenoid gasket, dist. o-ring, and cam end plug at the same time, but that didn't fix the leak. Then I replaced the other, smaller VTEC solenoid gasket and that seemed to fix it. #12 is what most people replace, but #14 is what fixed my leak.
http://www.acuraautomotiveparts.org/...t701_e1001.png |
i had oil in the same spot it was my vtec solenoid and my distributor O ring. In my case i replaced my head gasket just to find that out. Also looking at your second pick it looks like its the vtec solenoid gasket that mates to the head.
Originally Posted by sik96teg
(Post 44183835)
Originally Posted by CaliforniaDad
(Post 44184318)
Should i use honda bond on them?
(Post 44169891)
Okay will do. also dumb question. What is this oil plug here for?
That port can quickly be used to check the solinoid operation and health. When vtec is engaged, pressure there should be same as or close to oil press at the stock sensor location. Somewhre between 50 and 80. Depends on the age of the filter and pump. Its possible that the small filter is clogged or the solinoid isn't operating correctly. Pull it off and check the filter and you can put 12 volts to the solinoid and watch it operate.
