vtec dreams
what is the easiest way to vtec a LS chassis?
B16, b18c head/ecu swap...come on...
Re: (9000rpms)
i would think swap ... ls/vtec is a LOT of work
Re: vtec dreams (TEGN4SHO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEGN4SHO »</TD></TR><TR><TD CLASS="quote">what is the easiest way to vtec a LS chassis?</TD></TR></TABLE>
you dont own a civic but here is a helpful link that provides info on the different engines: https://honda-tech.com/zerothread?id=878010 BTW i have seen a lot of LS guys get B16s. |
Get a B16/GSR motor. https://honda-tech.com/forums/images...s/emsmilep.gif
Re: vtec dreams (EL Vap133)
you can't really vtec a chassis, however you can add a vtec head to the motor https://honda-tech.com/forums/images/smilies/emthup.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9000rpms »</TD></TR><TR><TD CLASS="quote">B16, b18c head/ecu swap...come on...</TD></TR></TABLE>
Thank you for your input, I feel so much smarter now. What I talking about is the harness. How do you make it work with VTEC? |
Either b16, b18c, lsvtec or crvtec. I depend your personal perference
Thank you for your input, I feel so much smarter now. What I talking about is the harness. How do you make it work with VTEC?</TD></TR></TABLE> You need a VTEC head to wire up VTEC. |
Re: (-DKap-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -DKap- »</TD></TR><TR><TD CLASS="quote">i would think swap ... ls/vtec is a LOT of work</TD></TR></TABLE>
and very hard to have a reliable one at that.. |
Re: (-DKap-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -DKap- »</TD></TR><TR><TD CLASS="quote"> ... ls/vtec is a LOT of work</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. »</TD></TR><TR><TD CLASS="quote"> and very hard to have a reliable one at that..</TD></TR></TABLE> wrong and wrong. geez. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr0jectjdm »</TD></TR><TR><TD CLASS="quote">Either b16, b18c, lsvtec or crvtec.</TD></TR></TABLE> |
Re: (LSvtec03)
search for the answers you need...
this thread is retarded.
all the guy wanted to know about was wiring. "you can't vtec a chassis..." "you can't run vtec without a vtec head..." ...for christ sake still.. use the search tegn4sho wait.. i'm a noob compared to you, why am i telling you this.. https://honda-tech.com/forums/images...s/emsmilep.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 »</TD></TR><TR><TD CLASS="quote">
wrong and wrong. geez. </TD></TR></TABLE> why, just cuz you have one? do a test. get a built ls/vtec aginst a stock b18c.. we'll see who outlives who |
Re: (..::91TEG-G2::..)
Should have covered this in the begining, the ls motor is going away and I am swapping a vtec motor, odb1 ecu and wiring on 97 b18c. I found a thread that covers the vtec solonoid and pressure switch. I have questions about the knock sensor and o2 sensor and will post the findings once everything is hooked and working. Any help will be appreciated, the motor does come until weds.
Thanks for the posts! https://honda-tech.com/forums/images/smilies/emthup.gif |
why, just cuz you have one? do a test. get a built ls/vtec aginst a stock b18c.. we'll see who outlives who</TD></TR></TABLE> i agree + ls arent made for a vtec they are built differently if ur not a pro at this shit ur gonna hav tons of realibilty issues |
Re: (-DKap-)
i agree + ls arent made for a vtec they are built differently if ur not a pro at this shit ur gonna hav tons of realibilty issues</TD></TR></TABLE> http://images.honda-tech.com/set1//smile/emcrook.gif the reliability isn't so much in the build (which is not rocket science, by the way), as it's in the way people treat it. people rev higher than their motor is capable, so they blow the motor, or it was put together by a complete idiot, and blew because of him. end of story. my ls bottom end and gsr top are completely stock, just like lots of others, many on h-t, and has been running perfectly with NO problems since last june when it was built, and it's not gonna be blowing any time soon. if you want to discuss this further, you can message me and i'll answer any questions for ya. https://honda-tech.com/forums/images...es/emsmile.gif |
Re: (LSvtec03)
wrong and wrong. geez. </TD></TR></TABLE> um yeah i agree 100 percent.. buy urself a golden eagle lsvtec converstion kit and its as simple as 123. maye sure ur oil line is tapped and the dowel slots no longer to be drilled because of the GE dowels... its cake. theres nothing about an ls vtec build that makes it less relaible if done right. dont rev much higher then a stock ls redline if you have a stock ls block tho.. that is still not able totake realy high revs because of the rod bolts for the most part. but even ARP has a solution for that. p28 ecu (vtec ecu) and an obd conversion harness n u skrait dawg... for work this large, its definfitly low on the difficulty scale |
Re: (tegsallgood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEGN4SHO »</TD></TR><TR><TD CLASS="quote">Should have covered this in the begining, the ls motor is going away and I am swapping a vtec motor, odb1 ecu and wiring on 97 b18c. I found a thread that covers the vtec solonoid and pressure switch. I have questions about the knock sensor and o2 sensor and will post the findings once everything is hooked and working. Any help will be appreciated, the motor does come until weds.
Thanks for the posts! </TD></TR></TABLE> ahhhh.... C that would have helped from the begging. Everyone thought u were tryin to vtec a Chassis. Very diff to put a vtec head on ur unibody..... anyways u just need the GSR ecu and also the wiring harness from the vtec motor. im pretty sure the o2 sensor is the same i may be wrong since ur doin 0bd1... so just search |
Re: (Integrt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsallgood »</TD></TR><TR><TD CLASS="quote">
um yeah i agree 100 percent.. buy urself a golden eagle lsvtec converstion kit and its as simple as 123. maye sure ur oil line is tapped and the dowel slots no longer to be drilled because of the GE dowels... its cake. theres nothing about an ls vtec build that makes it less relaible if done right. dont rev much higher then a stock ls redline if you have a stock ls block tho.. that is still not able totake realy high revs because of the rod bolts for the most part. but even ARP has a solution for that. p28 ecu (vtec ecu) and an obd conversion harness n u skrait dawg... for work this large, its definfitly low on the difficulty scale </TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif Couldn't have said it better... Go find a single person who blew their LS/VTEC who did not abuse their bottom end's limits <U>and</U> used the proper building technique (decking block, resurfacing the head, GE LS/VTEC kit or correct dowel conversion, fresh seals, gaskets, and bearings). You won't find a single one... |
Re: (psychotic_z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psychotic_z »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif Couldn't have said it better... Go find a single person who blew their LS/VTEC who did not abuse their bottom end's limits <U>and</U> used the proper building technique (decking block, resurfacing the head, GE LS/VTEC kit or correct dowel conversion, fresh seals, gaskets, and bearings). You won't find a single one...</TD></TR></TABLE> thanks mang. |
Re: (psychotic_z)
https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif Couldn't have said it better... Go find a single person who blew their LS/VTEC who did not abuse their bottom end's limits <U>and</U> used the proper building technique (decking block, resurfacing the head, GE LS/VTEC kit or correct dowel conversion, fresh seals, gaskets, and bearings). You won't find a single one...</TD></TR></TABLE> I gotta agree with you here man, but dont' forget improper tuning.. https://honda-tech.com/forums/images/smilies/emsad.gif https://honda-tech.com/forums/images/smilies/emsad.gif https://honda-tech.com/forums/images/smilies/emsad.gif |
Re: (drussell4801)
hey i have a 94 ls integ and i have a vtec dream..just want to kno whats a good engine i can get for this year. plannign to spen like maybe 2 or 3 grand.
Re: (Hype Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hype Vtec »</TD></TR><TR><TD CLASS="quote">hey i have a 94 ls integ and i have a vtec dream..just want to kno whats a good engine i can get for this year. plannign to spen like maybe 2 or 3 grand.</TD></TR></TABLE>
jdm h22.. i can sell you one. |
Re: (drussell4801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hype Vtec »</TD></TR><TR><TD CLASS="quote">hey i have a 94 ls integ and i have a vtec dream..just want to kno whats a good engine i can get for this year. plannign to spen like maybe 2 or 3 grand.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drussell4801 »</TD></TR><TR><TD CLASS="quote">
jdm h22.. i can sell you one.</TD></TR></TABLE> geez...there's already like 2 or 3 h22 threads right now. just do an lsvtec and turbo it. you'll be way happier. |
| All times are GMT -8. The time now is 02:27 PM. |
