Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Acura Integra (https://honda-tech.com/forums/acura-integra-6/)
-   -   Valve Cover (https://honda-tech.com/forums/acura-integra-6/valve-cover-1895260/)
RGK500 Feb 14, 2007 07:43 PM
Valve Cover
if i take my valve cover off do i have to change the gasket? because i took it off and adjusted my valves and put it back on with the same one and there are not any leaks that i see. Any Thoughts
Tizight Feb 14, 2007 07:59 PM
It would be a good idea.
boosted96teg Feb 14, 2007 08:20 PM
Re: Valve Cover (RGK500)
Ive taking mine off plenty of times to do valve adjustments and never changed my gasket. As long as u have it tucked in the groove of the valve cover and its not ripped u should be good.
ir0nmanx Feb 14, 2007 08:21 PM
Re: (Tizight)
Do you have to replace it everytime you take off your valve cover?
EDIT: Nevermind I just saw the post above.
Dunc Feb 14, 2007 09:18 PM
Re: (ir0nmanx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ir0nmanx &raquo;</TD></TR><TR><TD CLASS="quote">Do you have to replace it everytime you take off your valve cover?
EDIT: Nevermind I just saw the post above.</TD></TR></TABLE>
No you do not need to change it. It's just a rubber gasket, it is reuseable. Just make sure you wipe down both the gasket AND the head where the gasket goes with brake cleaner. You don't want oil there when you put the gasket back on. https://honda-tech.com/forums/images/smilies/emthup.gif
Dealer Leaf Feb 14, 2007 09:23 PM
Re: (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">
No you do not need to change it. It's just a rubber gasket, it is reuseable. Just make sure you wipe down both the gasket AND the head where the gasket goes with brake cleaner. You don't want oil there when you put the gasket back on. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
x2 and dont use any sealent what so ever you dont want that gunk in your head
BlUeDC2nEr Feb 14, 2007 10:01 PM
Re: (Dealer Leaf)
B series FTW Feb 14, 2007 10:07 PM
Sometimes you get lucky if it doesn't leak, but just make sure you use Honda bond around the corners, but it would also be a better idea to get a new gasket. It's pretty cheap like $20 max @ Honda dealer.
Dunc Feb 14, 2007 10:59 PM
Re: (Dealer Leaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dealer Leaf &raquo;</TD></TR><TR><TD CLASS="quote">x2 and dont use any sealent what so ever you dont want that gunk in your head</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B series FTW &raquo;</TD></TR><TR><TD CLASS="quote">just make sure you use Honda bond around the corners</TD></TR></TABLE>
^^^Not just the outside corners, but also the middle ones (the ones that go around the camshafts). You don't need a lot, just a light coating at those corners.
RGK500 Feb 15, 2007 07:56 PM
Re: (Dunc)
What about around the spark plugs. I pulled one of the spark plug wires out today and there was some oil on it. is it possable that i did not set it on strate because there is also some oil on the back of the cover where the washer and the nut is. and it also did not seam like it was lineing up on the two center studs.
CleanLikeJdm Feb 15, 2007 08:23 PM
Re: (RGK500)
The sparkplug ones can go bad easier then the one around the cover probably,
I bought a vc set just because of oil on the top of the plugs.
