Type R Exhaust on a GSR?
Old 02-19-2004, 02:22 PM
DSR!'s Avatar
Default Type R Exhaust on a GSR?
What do you need to do for a Type R exhaust to fit on a GSR?
Old 02-19-2004, 02:27 PM
Audi A4's Avatar
Default Re: Type R Exhaust on a GSR? (DSR!)
NADA, I PUT ONE ON MY LS BOLTED RIGHT UP. AND GS-R AND LS BOLTED UP FOR ME IN THE PAST, SO IM GUESSING IT ALL SHOULD BOLT UP
Old 02-19-2004, 02:29 PM
DSR!'s Avatar
Default Re: Type R Exhaust on a GSR? (DRAG lll INTEGRA)
Does that mean it'll bolt right on with out any minor mods? and would tha whole stock type r exhaust fit?(catback)
Old 02-19-2004, 02:32 PM
"Haters Gonna Hate"
FrostyDC4's Avatar
What year is your GSR?
nolexforever's Avatar
if i remember right, 94-99 integras use the same exhaust length, 2dr and 4dr are different from one another of course..i think 00-01 are a tad bit longer..i could be wrong.
Old 02-19-2004, 02:35 PM
DSR!'s Avatar
Default Re: Type R Exhaust on a GSR? (nolex7)
94 GSR
Old 02-19-2004, 02:36 PM
"Haters Gonna Hate"
FrostyDC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSR! &raquo;</TD></TR><TR><TD CLASS="quote">94 GSR</TD></TR></TABLE>
You will need to shorten the B-pipe
Old 02-19-2004, 02:39 PM
DSR!'s Avatar
Default Re: Type R Exhaust on a GSR? (FrostyDC4)
Yes Kristen Kreuk is hot, but i would guess that any shop could fix that problem for me?
Old 02-19-2004, 03:06 PM
Audi A4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSR! &raquo;</TD></TR><TR><TD CLASS="quote">Yes Kristen Kreuk is hot, but i would guess that any shop could fix that problem for me?</TD></TR></TABLE>
CORRECT
Old 02-19-2004, 04:29 PM
"Haters Gonna Hate"
FrostyDC4's Avatar
Yes
Old 02-19-2004, 07:28 PM
tub_sephiroth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostyDC4 &raquo;</TD></TR><TR><TD CLASS="quote">
You will need to shorten the B-pipe</TD></TR></TABLE>
You have to extend the B-pipe! I've been through it except it was the other way around.
Old 02-19-2004, 07:51 PM
jdmhamster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSR! &raquo;</TD></TR><TR><TD CLASS="quote">What do you need to do for a Type R exhaust to fit on a GSR? </TD></TR></TABLE>
for a usdm type r exhaust.. nothing.
for a jdm type r exhaust.. u gotta extend the piping lil bit cuz the jdm cat is longer than the usdm cat.
Old 02-19-2004, 07:54 PM
timmy8151's Avatar
Default Re: Type R Exhaust on a GSR? (jdmhamster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhamster &raquo;</TD></TR><TR><TD CLASS="quote">
for a jdm type r exhaust.. u gotta extend the piping lil bit cuz the jdm cat is longer than the usdm cat. </TD></TR></TABLE>
Actually, if its a 94-99 GSR, you're going to have to extend the b-pipe by 4.5". If its a 00-01 GSR, then its a direct fit.
The-LS's Avatar
you MUST extend the B-pipe about 5-6" Done it before
Old 02-19-2004, 07:55 PM
The-LS's Avatar
Default Re: Type R Exhaust on a GSR? (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">Actually, if its a 94-99 GSR, you're going to have to extend the b-pipe by 4.5". If its a 00-01 GSR, then its a direct fit.</TD></TR></TABLE>
jdmhamster's Avatar
ah okok.. didn't know that. haha thanx
mine is a 98 gsr and i had to lengthen. didn't know they changed it for 00+
Old 02-19-2004, 09:18 PM
ECKOTYPER's Avatar
this is what i did since i have rs*r exhaust and wanted stealth look with itr muffler, had them chop rs*r muffler where the muffler ends, same with itr discard itrs axelback piping, and weld itr muffler to rs*axelbacks piping =D and then sold rs*r exhaust, same performance, less noticable =D
Old 02-20-2004, 09:49 AM
DSR!'s Avatar
Default Re: (ECKOTYPER)
b pipe is the mid piping right?
so if i dont get the b pipe will it bolt up to the axle back portion of the exhaust with out mods?
Old 02-20-2004, 12:37 PM
BlackSage's Avatar
Default Re: (DSR!)
if u are asking if the itr muffler will bolt to your gsr b pipe, I believe the answer is yes.
BTW. I am running an itr exhaust on a 00 gsr. Exhaust came from a 00 itr. No modifications needed whatsoever.
Old 03-02-2004, 10:32 PM
98B18C1's Avatar
will a 2001 itr catback bolt rite onto a 98 gsr? if not wat kinda mods will be needed?
Old 03-02-2004, 10:33 PM
BlackSage's Avatar
Default Re: (98B18C1)
length of b pipe will need to be changed. I believe the itr exhaust will need to be shortened by 4 inches
Old 03-02-2004, 10:47 PM
SMZ GSR's Avatar
this is correct. I've done the same on my 98 GSR
Old 03-03-2004, 05:44 AM
quikB18B's Avatar
This is Correct If you had an Ls it wil bolt up directly. I can't remember if the header or the cat thats shorter but one of them is. Someone posted a diagram once showing the difference between the Ls, Gsr, and Itr.
You'll need to have it extended about 4-5", but thats no biggie.
Old 03-18-2004, 11:39 AM
98B18C1's Avatar
i got my itr catback on my 98 gsr and my check light came on. anyone know wat the problem is?? i turned it off but whenever i start my car up again, it keeps coming on.
Old 03-18-2004, 12:00 PM
SMZ GSR's Avatar
forget to plug the O2 sensor back in?
Quick Reply: Type R Exhaust on a GSR?
