type-r pistons in my B18C1?
anyone know where about's my compression would be if i dropped some ITR pistons in my B18C1? im already gettin the eagle crank and rods, plus i have valve work done.. so.. im just tryin to figure out where my compression would be.. THANKS GUYS!
Re: type-r pistons in my B18C1? (jennsGSR)
They'll fit just fine in the motor, however they will not fit with the eagle rods. Stock rods have the wrist pins pressed into them (to prevent the wrist pin from falling out) and the eagles use a full float design and then use c-clips on the pistons (all aftermarkets have them) to hold in the wrist pin. If you're going to buy the eagle crank, shouldnt you want more performance then the OEM pistons can hold anyway?
ricky05
02-23-2006 06:13 AM
