tail lights dont work
My tail lights arent coming on while im driving but all brake lights come on when i press the break,checked the "light" fuses all look good...HELPP
Re: tail lights dont work
Originally Posted by blkbond8065
(Post 50497965)
Did you replace them recently? If not were they working properly before?
The bulb might be dead, It will have 3 bulbs, one lights up when you hit the brake, check those, have a buddy press the brake pedal while the bulbs are out the tail light sockets to confirm if there turning on or not.
(Post 50497965)
Originally Posted by EnjoyTheRideDC2
(Post 50503054)
You must have missed a fuse or didn't check correctly. The only way your tail lights wont power on as you describe is if a fuse is blown. The brake lamp and headlights are on their own independent fuse links, which is why they're still functional. The parking lamp fuse is what you're looking for.
I this problem, my lights were real funky.
(With the lights switched on), find the wiring harness's that plug into the taillights, take each wire that go into the socket and wiggle them/try to push them into the socket (they get pulled out when previous owners carelessly unplug them by tugging on the wires). |
Originally Posted by 95gsr@530
(Post 50503201)
which fuse number is the parking lamp fuse? i'm having the exact same problem and when I found a fuse that was blown for the starter signal it was blown, I replaced it, and still no tail lights.
It's the 10a fuse next to the starter signal. If you change the fuse and the lights still dont turn on, chances are its blown again. That means somewhere you have a short amongst the 3 light circuits listed for that fuse. Maybe a broken bulb, melted bulb holder, exposed wires touching, poor wire connections from an alarm or sidemarker install? Those are a few possibilities. It's tough to diagnose an issue like this without seeing the car and knowing if anything had been done to the car prior to the lights not functioning. |
