idle rpms
Old 11-26-2012, 06:44 PM
rick1361's Avatar
Default idle rpms
Why does the engine in my. 1990 integra. The rpms race up to 2500 then down to 1000 rpms when the engine is cold. It goes away after the engine warms up.
Old 11-27-2012, 06:35 PM
Hanmin's Avatar
Default Re: idle rpms
I would go ahead and clean the iacv and fitv, if that doesn't fix your problem, then i would search for a vacuum leak.
Are you sure it doesn't bounce when it warms up? not even a little bit?
Old 11-27-2012, 08:11 PM
Coopa B18c5's Avatar
Also does it stay at 1000 rpm even when its warmed up and at optimum temperature? 1000 rpm is pretty high for a up to temperature motor, no? I know my motor after being warmed up goes from idling normally at 600-700 rpm to randomly jumping and staying at 1000 rpm which in result disables my vtec...
Old 11-28-2012, 02:35 PM
jeresaur's Avatar
i had the same problem..mine idled like at 900k almost 1k..cleaned the iacv (behind the intake manifold) with brake cleaner threw it back on then POW! nice low idle..600-700k
AtoZ
02-10-2009 01:37 PM
ge_itr
10-16-2007 05:12 PM
Shauntron
04-25-2007 12:06 AM
Dawsonb17a
06-19-2004 03:44 PM
Quick Reply: idle rpms
