Rust prevention
Old 06-21-2013, 09:16 PM
rak511's Avatar
Default Rust prevention
Little concerned about rust because my last integra was rusted out. What can I do to prevent it, getting painted soon. Was thinking of undercoating rear wheel wells, and spare tire compartment, and frame rails with the spray can undercoating? Good, bad? suggestions? Thanks
Old 06-22-2013, 06:35 AM
S2BumpsticksGSR's Avatar
Default Re: Rust prevention
Pull off the plastic rocker panels and rear wheel well edge protectors. Start rust proofing those after they're thoroughly cleaned/descaled. Rear trailing arm mounts to body areas/wheel wells. Rear subframe and don't forget under battery tray up front and check front door jambs/hinge areas.
Old 06-22-2013, 07:46 AM
rak511's Avatar
What should I rust proof it with?
Old 06-22-2013, 09:03 AM
I just use a wire-wheel on a drill/grinder and get rid of any build-up. There's a number of rust proofing agents @ auto store. I don't know that any are better than the rest. I just spray a couple of heavy coats of gloss black krylon After I've cleaned/removed the crusties off. If you pull the plastic rockers be careful not to overtighten fasteners when assembling- they strip very easily.
Old 06-22-2013, 10:22 AM
rak511's Avatar
Alright, thanks!
Old 06-22-2013, 10:27 AM
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
Get some LPS 3 and spray the crap out of those areas from time to time,also take out the interior panels and spay the lowest parts inside the doors and inside the inner wheel wells rust often starts on the inside,this stuff is good enough for float plane owners to use it to stop fusealage rust in salt water areas
Old 06-22-2013, 05:24 PM
fcm
Old Fart
fcm's Avatar
RustBullet... http://www.rustbullet.com/?source=ad...FY9eQgodjwsA4g
As mentioned rear wheel arch protectors, they are the most common cause of rusting on Integras, remove them and toss them, [DO NOT reinstall them]. 94
Old 06-22-2013, 05:39 PM
PanchoEK's Avatar
POR 15!!!!
I believe that the best solution to prevent rust, like stated above grab a wire wheel and once you get down to metal, put that POR 15 on, it does not have UV protection, so it has to have something over it if its going to be exposed to sunlight.. it can be sanded and be painted over it
Old 06-24-2013, 05:39 AM
COLIMA0003ITR's Avatar
por 15 the best
xLaziestLa0b0ix
Honda Civic (2001 - 2005)
10-29-2009 02:49 PM
Razr2
23
04-04-2009 06:47 PM
Sardawg
12-18-2005 12:17 PM
schnaeringer
06-05-2004 03:58 PM
Quik89Si
01-12-2003 01:22 PM
Quick Reply: Rust prevention
