Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Acura Integra (https://honda-tech.com/forums/acura-integra-6/)
-   -   Shift Linkage pin (https://honda-tech.com/forums/acura-integra-6/shift-linkage-pin-1038655/)
Rod. Oct 28, 2004 07:21 PM
Shift Linkage pin
not trying to be hard headed or cheap. When you pop out the shift linkage pin they tell you not to use it again. What really happens if you reuse it. I couldnt find a thread on it. Thanks
LSvtec03 Oct 28, 2004 07:26 PM
Re: Shift Linkage pin (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">What really happens if you reuse it.</TD></TR></TABLE>
nothing https://honda-tech.com/forums/images...s/emsmilep.gif
aznballer Oct 28, 2004 07:27 PM
i think its not reusable that why, just get a new one
Cjsls Oct 28, 2004 07:38 PM
Re: (aznballer)
i've reused mine before. only cause it was sunday and the dealer was closed and i needed to fix the car.
CRX_1.8T Oct 28, 2004 08:10 PM
i think that they say that in case it breaks after re-use. maybe their way of not being responsible for old and worn out parts that may malfunction after being tinkered with too much. who knows?!
Electron_LS-Vtec Oct 28, 2004 09:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">not trying to be hard headed or cheap. When you pop out the shift linkage pin they tell you not to use it again. What really happens if you reuse it. I couldnt find a thread on it. Thanks</TD></TR></TABLE>
Take the old one with you and go to a hardware store...they sell compression pins in all differenent sizes for maybe 2 dollars.... https://honda-tech.com/forums/images/smilies/emthup.gif
rovigian Oct 28, 2004 10:30 PM
Re: (Cjsls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cjsls &raquo;</TD></TR><TR><TD CLASS="quote">i've reused mine before. only cause it was sunday and the dealer was closed and i needed to fix the car.</TD></TR></TABLE>
Me too, sundays are hell to work on a car for that reason.
MyBigNut Oct 29, 2004 12:23 AM
Re: (rovigian)
Dont worry yourself too hard, you can reuse it
DontBlink Oct 29, 2004 05:11 AM
Re: (MyBigNut)
i never bought a new one and i never seen or heard of one ever falling out, they dont slide back in you have to tap them in with a hammer, trust me its not going anywhere.
AngelTeg Oct 29, 2004 05:29 AM
Re: (DontBlink)
ya, you can reuse... just I know there are alot of people out there that mash them up pretty bad removing them, if that happens its kinda hard to re-use them.
but as everyone said, just pop it back in there...
-Mike
hypa Oct 29, 2004 08:31 AM
Re: (AngelTeg)
If you're gentle taking it out, you can easily reuse it. Be sure to install the safety spring that surrounds the pin though, as that's the most important part.
Gsr_Hybrid_theory Oct 31, 2004 08:18 AM
Re: (hypa)
uchk if you buy a new pin you WILL kill yourself trying to put it in... holy christ i wanted to throw the fkin thing away... my god... what a pain... esp 2-3" above me...
s2kkid Oct 31, 2004 09:46 AM
Re: (hypa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa &raquo;</TD></TR><TR><TD CLASS="quote">If you're gentle taking it out, you can easily reuse it. Be sure to install the safety spring that surrounds the pin though, as that's the most important part.</TD></TR></TABLE>
Shit... HOW?
i tapped with a hammer forever, I finally got pissed off bad enough and put an air hammer on it, and it got it out....
Rod. Oct 31, 2004 10:02 AM
Re: (vtecluder97)
a punch and hammer for taking it out https://honda-tech.com/forums/images/smilies/emthup.gif
blusmke Oct 31, 2004 10:33 AM
Re: (redturbocivic)
or you could just use a bolt. I've reused every time I have done it never had a problem.
Rod. Oct 31, 2004 10:56 AM
Re: (blusmke)
I just popped it back in and it shifts fine. THanks everyone
blusmke Oct 31, 2004 11:19 AM
Re: Shift Linkage pin (Electron_LS-Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Electron_LS-Vtec &raquo;</TD></TR><TR><TD CLASS="quote">
Take the old one with you and go to a hardware store...they sell compression pins in all differenent sizes for maybe 2 dollars.... https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
Just put the old one in and save your two dollars for a big gulp from 7-11. https://honda-tech.com/forums/images/smilies/emwink.gif
hypa Nov 1, 2004 10:36 AM
Re: (vtecluder97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecluder97 &raquo;</TD></TR><TR><TD CLASS="quote">i tapped with a hammer forever, I finally got pissed off bad enough and put an air hammer on it, and it got it out....</TD></TR></TABLE>
AIR HAMMER!
woot.
It's the best way to do it. Just be sure you use the proper sized punch as not to mushroom the pin. To install, I gently tighten it in a vice grip, and press it in as far as I can, then use the air hammer again to tap it in all the way.
PlastikOwl Nov 1, 2004 11:32 AM
Re: (hypa)
I've always reused the pin.
