Raise b18b1 redline
so guys, I am doing a little project before I go to college, a fun turbo build, here is what I am doing,
eagle rods with arp rod bolts wiseco pistons with 81.5mm bore and 9.3:1 ratio stock sleeves kings rod and main journal bearings arp head studs then a nice turbo kit and looking for around 325whp-350whp and I already have a b16 tranny with yonaka stage 3 clutch and act streetlite flywheel what I want to know now is can I build the head with all brian crower parts and a stage 2 turbo cam, would it be safe to rev up to 8k rpms? with a build head of course |
Re: Raise b18b1 redline
With the correct valvtrain I would think so.
8000..probably but with the rocker arm design i personally wouldnt go over that and would feel more comfortable with like 7500-7800.
dont get a turbo cam if you want cams i'd say to go with the 403's. if you are going to rev over 7500 you need to use a 22 tooth vtec water pump. final parting words: you are going to hate having a straight b16 transmission over time. it will feel like it runs out of gearing especially up top. if possible i would recommend a gsr trans or at least a gsr 4th and 5th on the b16 1st thru 3rd gear |
Balance the cost of all that against a vtec conversion. Then the sky is the limit and the low end is better too.
Originally Posted by blackeg
(Post 49503300)
Originally Posted by GagnarTheUnruly
(Post 49503303)
Originally Posted by Jdm_Ej8_Sedan
(Post 49503336)
if I don't build the head can I raise the redline to 7500 with no problems? and I have been looking into a gsr transmission because the b16 is so short geared I feel like it tops out too fast as it is, but thanks for the input.
TBH there is not much need for 8k redline. You can get plenty of power for the street with a turbo at stock revs.
Gsr/type r oil,waterpump and timing belt
