Radiator Fan Relay and Wiring questions 90-93
When I was cleaning up the engine bay on my DB1, I got a bit confused as to what was what and apparently snipped off the radiator fan relay. And then threw it out. So now I have to wire it up from scratch, which is no biggy, but I'm missing a wire.
https://farm3.static.flickr.com/2031...5ea557950a.jpg OK, I have the ylw/blk & blk/ylw wires that trigger the relay... that's where I made the snip, and everything past that is gone. The only thing left on that harness aside from the headlight/turn signal wiring are 2 plugs that are either for ABS or A/C, or maybe neither... hell, I have no idea what those two plugs are for, but I'm not currently using them. I've checked out the electrical diagram in the manual, and as I understand it, the only thing I'm missing is a power source (white wire) going into the relay (comes out blue and goes to the fan). I only snipped the 2 wires, so I'm not sure where that white wire comes from. I could always go straight to the battery or fuse box, but I'm trying not to add long wires if I don't have to. Is that white wire in one of those two plugs that I'm not using by any chance? Thanks. Modified by steronz at 3:10 PM 5/20/2008 |
